Author Topic: ...  (Read 12369 times)
Offline cleaningOutTopic starter
  • Country: cz
« on: June 20, 2017, 03:50:47 pm »
« Last Edit: May 27, 2018, 03:55:15 pm by cleaningOut »
Offline ebclr
Re: Someone is selling Artix-7 Zynqs at a massive discount - legit?
« Reply #1 on: June 20, 2017, 04:20:31 pm »
He accept offers also
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #2 on: June 20, 2017, 04:29:08 pm »
Seems so. Those are "leftover stock" carrying a 1309 date code, so it is likely that those chips are long past their expiry date and are forced to write off.
If you have the right tools for the BGA you can buy some, bake them, and build a DIY experimental board from them. You will need at least some DRAM for it though.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #3 on: June 20, 2017, 04:56:20 pm »
So they're almost four years old... wow. I wonder where this guy got them.
The original company that bought those chips probably dumped them as they wrote them off as expired. Whoever received the dump decided to treat them as NOS and resell them.
This is the same reason why there was a time when Xeon E5-2670 and E5-2680 processors was dirt cheap - Facebook and Amazon decommissioned datacenters worth of servers and dumped them to e-waste processors. The e-waste processors treated the processors and memory sticks that are standard products as perfectly resalable second hand and dumped them to the second hand market, causing the street price of the chips to plummet. I grabbed two of them at the cost of 1/3 of a single E5-2620v2 that was used in the same server.
Offline andyturk
« Reply #4 on: June 20, 2017, 08:09:33 pm »
How would you go about baking these?
Offline KE5FX
    • KE5FX.COM
« Reply #5 on: June 20, 2017, 09:54:32 pm »
Easier said than done... these are 0.8mm pitch BGAs! Any boards you build to use these are going to be wildly expensive in low quantities.
Meh.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #6 on: June 21, 2017, 05:43:36 am »
It's just 0.8mm BGA, not that hard. 0.5mm is like a bitch, and 0.4mm is much harder.
For 0.8mm, you can still use dog bone fanout.
Sure, but going from 4 to 6 layers quadruples the price of the PCB. Any fabs you recommend?
I don't know if Zynq requires 32-bit DDRIII, but I've done 16-bit DDRIII for iMX6ULL, and that's doable with 4-layer, 0.2mm drill and 0.1mm track process without any advanced tech such as blind/buried vias, HDI and so on.
Top: trace
M1: GND/PWR
M2: GND
Bot: trace
It can do 8-, 16-, 18- and 32-bit DDR3. (18-bit DDR3 is 16-bit DDR3 with ECC.)
Offline eeviking
« Reply #7 on: June 23, 2017, 02:07:01 pm »
Hi guys. I am the ebay seller of the Zynqs.
As technix have correctly guessed they are legit and were rescued from going to the dump due to expired shelf life.
If you want me to change the description I will be happy to do that.
They are MSL3 and should be baked before reflow. (The standard says 9h at 125C, 33h at 90C or 13days at 40C <5%RH)
I will try to ship air tight with silica gel, but I do not have access to vacuum pack.
If anyone have a simple open source board layout for them it would be nice ?
« Last Edit: June 23, 2017, 02:16:11 pm by eeviking »
The following users thanked this post: Frank, KE5FX
Offline Sal Ammoniac
« Reply #8 on: June 23, 2017, 02:51:23 pm »
Expired? How the hell do chips "expire"?
"That's not even wrong" -- Wolfgang Pauli
Offline tszaboo
« Reply #9 on: June 23, 2017, 02:53:34 pm »
How many do you have? If it is in the 100s it might be even worth to design something for it. Like couple it with DDR and some flash, route the rest to castellations. Selling that many otherwise might be hard.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #10 on: June 23, 2017, 02:56:06 pm »
Unsoldered chips have an expiry date after which the pins may become too oxidized to solder using normal thermal profile, flux and solder paste. Either the chips have to be reballed/reworked or new chips have to be bought. Most company would not bother hiring someone to rework the chips, so they write them off as expired and buy new chips.
For us tinkerers the reballing is a price to pay for buying the chips on the cheap, but with an hour or two of our work we can make use of a super expensive chip without actually paying a lot of the money.
« Last Edit: June 23, 2017, 02:59:31 pm by technix »
The following users thanked this post: nowlan
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #11 on: June 23, 2017, 02:58:57 pm »
I would definitely like to buy a few of that. Oh you also need to put the PMIC on the module too.
Also you may want to provide an evaluation board for the castellated module so people can get one and start playing with it. For such modules the Raspberry Pi pinout may be a good idea.
Offline NorthGuy
« Reply #12 on: June 23, 2017, 03:13:20 pm »
It's about $500, if not more, to print a minimum amount of 6-layer ENIG boards with 4mil traces (5mil might be Ok though) and 8mil drills. This will kill all the savings from buying your chips.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #13 on: June 23, 2017, 03:24:49 pm »
For now store them in a dry hot room with bags of rice surrounding them. The rice grains are very hydrophilic and can pull the moisture out of the chips.
Is there anything else you have rescued from the dumpster? I do like to stock up some FPGA in QFP packages. (hand soldering does not mind the moisture level, and I can use some sand paper to quickly dispatch the corrosion.)
Offline eeviking
« Reply #14 on: June 23, 2017, 03:59:24 pm »
I only have about 50 left.
Offline eeviking
« Reply #15 on: June 23, 2017, 04:01:35 pm »
I don't think the solderability will be a problem, they have been stored at <5%RH
The expiration date is set to ensure 100% yield witch is important if you produce stuff like offshore electronics and you don't want to take any risks. For hobby/prototype use it's not a problem.
They are stored in sealed bag with silica gel packs. I think they are better than rice  ;)
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #16 on: June 23, 2017, 04:02:48 pm »
It is the oxygen in the air that killed the solderability, not the humidity.
Big bags of rice would work much better than a small packet of silica gel.
Offline eeviking
« Reply #17 on: June 23, 2017, 04:09:20 pm »
Yes, but high temperature and humidity will accelerate the oxidation.
I use big bags  ;D
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #18 on: June 23, 2017, 04:57:55 pm »
I use big bags  ;D
Even in cool dry air the oxidation will ha;pen, albeit much slower. But those chips have been sitting on a shelf for more than 4 years...
Have you rescued other chips from the dumpster?
Offline KE5FX
    • KE5FX.COM
« Reply #19 on: June 23, 2017, 06:36:51 pm »
This kind of thing matters in ISO-compliant processes where procedures must be documented in detail and perfectly reproducible, where the difference between five-sigma quality and six-sigma matters.  Or if you're sending hardware to the Kuiper Belt.  For every other application, from prototyping to limited production runs, they'll be OK.
Offline Koen
« Reply #20 on: June 23, 2017, 08:17:02 pm »
AllPCB have a special on leaded HASL 6-layers at 70 USD for 10 boards of 100x100.
Offline NorthGuy
« Reply #21 on: June 23, 2017, 09:22:04 pm »
You cannot really fan it out with 6mil wires and 12mil holes. They don't publish a separate "hole to copper" specs, but assuming it's the same as with annular ring: 12mil hole + 2*6mil annular ring + 2*6mil gaps + 6mil trace = 42mil, but the distance between ball centers is only 31 mil. So you only will be able to do the outer row of balls (perhaps the second row if you undersize ball pads). I don't think HASL would work neither.
Offline eeviking
« Reply #22 on: October 23, 2017, 12:07:02 am »
Did anyone get boards made with these?
Any problems with solderability?
I still have some left I plan to dump for a good price in the buy/sell section.
Offline asmi
« Reply #23 on: October 23, 2017, 03:21:07 pm »
I've been thinking about designing a board for this SoC. Recently I found a fab that quoted me $234 for 10 6-layer boards with 0.1/0.1 mm traces and 0.2 mm drills and CI (and that price includes DHL delivery to my door), but I would like to see them deliver before I can formulate my opinion. If these parts would still be available at the time, I will definitely buy several - don't mind baking them at all.
Offline Tomorokoshi
« Reply #24 on: October 23, 2017, 05:19:07 pm »
Now that sounds like an interesting kickstarter campaign!
