Author Topic: STC12C5A60S2 Development Board - Software & Resources?  (Read 172 times)
Offline Chris56000
« on: June 21, 2019, 01:57:38 pm »
Hi!
Just another quickie one!
Can anyone point me in the direction of software links, tutorial resources, etc., to use this STC Development Board I bought?
Does it ONLY support the STC12C5A60S2 or will other devices work with it?
Will it program this device, or should I buy a dedicated programmer?
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline PCB.Wiz
Re: STC12C5A60S2 Development Board - Software & Resources?
« Reply #2 on: June 22, 2019, 08:44:58 pm »
STC I think have Serial bootloaders in all their parts, so any of their pin-compatible DIP40 parts would work in that board.
To pgm serially, you just need to get into the serial port, which means either a USB-UART-TTL for direct pin connect, or a USB-full RS232 is you already have RS232 level shifters on the board.
 Looks like your board has the DB9 + RS232 level shifters fitted.
« Last Edit: June 22, 2019, 08:46:32 pm by PCB.Wiz »
