Hello all I am José and this is my first post.
I want to move a stepper motor using Matlab but I do not know what is wrong. The motor does not move.
Materials:
Arduino Uno
TB6600 Motor Driver
Motor: 28HB30-401A
Arduino Suport Package for Matlab
The next code works ok, it is for the Arduino IDE.
int BOTON_1 = 7; //SELECCIONAR
int BOTON_2 = 8; //MOVER
int LED_1 = 5; //ENCENDER AVANCE
int LED_2 = 6; //ENCENDER REVERSA
int ENA = 3; //ENABLE A PIN 3
int DIR = 2; //DIRECCION PIN 2
int PUL = 4; //PULSO PIN 4
void setup() {
pinMode(BOTON_1, INPUT_PULLUP); //SE DECLARA PIN 7 COMO ENTRADA
pinMode(BOTON_2, INPUT_PULLUP); //SE DECLARA PIN 8 COMO ENTRADA
pinMode(LED_1, OUTPUT); //SE DECLARA PIN 5 COMO SALIDA
pinMode(LED_2, OUTPUT); //SE DECLARA PIN 6 COMO SALIDA
pinMode (PUL, OUTPUT); //SE DECLARA PIN 4 COMO SALIDA
pinMode (DIR, OUTPUT); //SE DECLARA PIN 2 COMO SALIDA
pinMode (ENA, OUTPUT); //SE DECLARA PIN 3 COMO SALIDA
void loop() {
if (digitalRead(BOTON_1) == HIGH){ //SELECCION 0-> RETROCEDER; 1-> AVANZAR;
if (digitalRead(BOTON_2) == HIGH){ //BOTON_2
digitalWrite(LED_1, LOW);
digitalWrite(PUL,HIGH); //PARA MOTOR
else {
digitalWrite(LED_1, HIGH); //AVANZA
digitalWrite(DIR,LOW);
digitalWrite(ENA,HIGH);
digitalWrite(PUL,LOW);
else{
digitalWrite(LED_2, LOW);
else{
digitalWrite(LED_2, HIGH); //RETROCEDE
digitalWrite(DIR,HIGH);
The next code is the same but for Matlab and the motor does not move
a = arduino('COM8','Uno');
configurePin(a,'D2','DigitalOutput'); % DIRECCION - PIN 2
configurePin(a,'D3','DigitalOutput'); % ENABLE - PIN 3
configurePin(a,'D4','DigitalOutput'); % PULSO - PIN 4
configurePin(a,'D5','DigitalOutput'); % LED 1 ENCENDER AVANCE
configurePin(a,'D6','DigitalOutput'); % LED 2 ENCENDER REVERSA
configurePin(a,'D7','Pullup'); % BOTON 1 SELECTOR
configurePin(a,'D8','Pullup'); % BOTON 2 MOVER
while 1
if readDigitalPin(a,'D7') == 1 % 1 --> AVANZAR / 0 --> RETROCEDER
if readDigitalPin(a,'D8') == 1 % HACER NADA
writeDigitalPin(a,'D5',0); % D5 LED 1 APAGADO
writeDigitalPin(a,'D4',1); % D4 PULSO ALTO --> PARAR MOTOR
else
writeDigitalPin(a,'D5',1); % D4 LED 1 ENCIENDE
writeDigitalPin(a,'D2',0); % DIRECCION --> BAJO PARA AVANZAR
writeDigitalPin(a,'D3',1); % ENABLE --> ALTO
writeDigitalPin(a,'D4',1); % PULSO --> ALTO
writeDigitalPin(a,'D4',0); % PULSO --> BAJO
end
else
writeDigitalPin(a,'D6',0); % D6 LED 2 APAGADO
else
writeDigitalPin(a,'D6',1); % D8 LED 1 ENCIENDE
writeDigitalPin(a,'D2',1); % DIRECCION --> ALTO PARA RETROCEDER
end
end
end
Please help me.
