Not related to the specific question, but related to the subject of gpio atomicity- I would imagine mbed is not protecting the modification of all the other gpio registers (no one does). No reason code to setup/change a pin cannot exist in more than 1 run level, so modifying a gpio port register other than the bsrr/brr write would need to be protected since the pins share these registers. Probably a common thing to miss, and only the odds of it happening being very low prevent anyone from noticing.
I have a blinky example in compiler explorer for an stm32g031, where both the rcc enable and modification to the non-bsrr/brr registers are protected-
https://godbolt.org/z/e6qehfvxMOf course the probabilities are low, but once seen I don't think its something you would want to ignore. In general, I think hardware registers are easily overlooked when it comes to atomic writes. Another good example would be the stm32 rcc registers which have quite a mix in them so is another peripheral that may see frequent use among different functions at various times and various run levels.
