Author Topic: STM nuclo32-l32kc Timer1 internal clock and GPIO on pin PA12  (Read 90 times)
Offline conducteur
Hi
I'm learning STM32 microcontrollers, and there's something that I don't really understand.
It seems that I can't assign Timer1 with an internal clock because I need PA12  as GPIO Output?
I tried to find more details in the datasheets, but did not find it. I don't see why a GPIO pin blocks the use of this timer?
I want to use ch1 for input capture, but this is on a different pin then PA12 (PA8).
[attachimg=1]
Offline gamalot
  • Correct my English
    • Youtube
Re: STM nuclo32-l32kc Timer1 internal clock and GPIO on pin PA12
« Reply #1 on: May 06, 2021, 03:48:52 pm »
No, the internal clock will definitely not conflict with a GPIO pin. There will be conflicts only when you select an external clock source. For example, selecting ETR2 will conflict with PA12 set to GPIO output mode.
Offline conducteur
« Reply #2 on: May 06, 2021, 03:57:42 pm »
Oh thank you. I misunderstood the warning. It's seems logical that it only relates to the options in pink.....
thank you!
