Author Topic: A problem with STM Studio  (Read 2188 times)
Offline VanitarNordicTopic starter
« on: July 28, 2018, 07:56:59 pm »
When I want to import variables from the .elf file (generated by the TrueStudio, inside the Debug folder) into the STM Studio software, I get the below error. When I press OK and bypass it, it shows a list of variables, but none of them gets imported.
« Last Edit: July 28, 2018, 10:39:51 pm by VanitarNordic »
Offline lucazader
Re: A problem with STM Studio
« Reply #1 on: July 29, 2018, 06:14:55 am »
Wehn you are compiling the elf file you are using with STM Studio, are you compiling with debugging information (eg -g flag with gcc)?
« Reply #2 on: July 29, 2018, 06:53:30 am »
Yes, even I have tested it with -g3, but the same results. I use TrueStudio
