Author Topic: Help - Regarding AN955 motor control application  (Read 355 times)
Offline Jayy
« on: December 04, 2018, 06:05:00 pm »
I would like to know if i can substitute  component for a outdated component in Microchip APPNote AN955 IRAMS10UP60A with IR2109 as in AN889.
http://ww1.microchip.com/downloads/en/AppNotes/00955a.pdf
Page - 20 , IRAMS10UP60A <- outdated component
http://ww1.microchip.com/downloads/en/AppNotes/00889b.pdf
Page-19, IR2109
Thanks,
Jai.
Online H.O
Re: Help - Regarding AN955 motor control application
« Reply #1 on: December 06, 2018, 03:19:09 am »
Short answer is no. The IRAMS10 is a complete "power brick" with gate drivers, switches , protection circuitry etc while the IR2109 is simply a half bridge driver meant to control a pair of external switches.
You'd need 3 IR2109 with surrounding support components, 6 MOSFETs or IGBTs and careful attention to PCB layout in order to replace the IRAMS module.
Digikey still have a couple of the 6A version of that module in case you want to try that. Otherwise I'm sure there other similar modules available, just go to Digikey and look in the Power Drive Modules category.
Offline Jayy
« Reply #2 on: December 08, 2018, 06:15:28 pm »
Thanks for your reply.
Can you explain if the firmware signals produced for IRAMS10 by AN955 firmware, require changes to drive the IR2109.
