Author Topic: STM32 SPI: How to properly send 8bits?  (Read 1529 times)
Offline WillHuangTopic starter
« on: December 30, 2016, 05:57:35 am »
I have a function here that compiles and works fine (i.e. I'm getting the output that I want) for sending 8 bit data frames on the SPI bus for the STM32F3 dev. board.
void SPI1_Transfer8(uint8_t data)
    uint8_t dummy;
    (volatile uint8_t)SPI1->DR = data;
    //SPI1_DR = data;
    SPI1->CR1 |= SPI_CR1_SPE;
    SPI1_Disable();
Although I can compile the code fine, Keil is showing me an error on line
How can I fix this?
Thanks in advance!
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: STM32 SPI: How to properly send 8bits?
« Reply #1 on: December 30, 2016, 06:35:26 am »
General rule: you can't cast the left side of an assignment.
Also, it will give an hardfault when try to force this.
The peripheral registers have to be accessed by half-words (16 bits) or words (32 bits).
The SPI1->DR register is already defined as an volatile uint16_t in the header. C will perform an implicit type conversion when you use it.
And you will have to wait for SPI to finish. The SPI Master is completed when RXNE = 1 and BUSY = 0.
« Last Edit: December 30, 2016, 06:37:58 am by Jeroen3 »
