I have a uC connected to a 74HC595 shift register.
One GPIO0 is connected to HC595 "SER" (serial input) and GPIO1 is connected to both SRCLK and RCLK, i.e. tied together.
This simple programme will only work (it just runs through 0-255 to show-up on the LEDs attached to the HC595 outputs) if I add-in the last "pulse" just before the delay (the delay just aids viewing):
while(1)
for (int display = 0; display < 256; display++)
for (int count = 0; count <8; count++)
GPIObits.GP0 = (display >> count) & 1;
GPIObits.GP1 = 1;
GPIObits.GP1 = 0;
GPIObits.GP1 = 1;
GPIObits.GP1 = 0;
__delay_ms(1000);
Without this extra, the numbers are not shifted far enough by one place.
Is this because the RCLK requires the extra pulse to copy the shifted bits into the output "stage"?
Cheers.
