Author Topic: New TI Tiva C Series Launchpad EK-TM4C1294XL  (Read 32232 times)
Offline bingo600
Re: New TI Tiva C Series Launchpad EK-TM4C1294XL
« Reply #50 on: March 19, 2014, 12:37:32 pm »
Got my two EK-TM4C1294XL , with XM4C129 chips
Decided to skip the "Unknown connect" to the demosite , and build + load "blinky"  - D1 is blinking green
I'm using GCC , and the nice template from here , and the lm4flash (as root)
https://github.com/uctools/tiva-template
Connect the debugport with the USB cable and fire away:
build $ sudo /home/bingo/bin/lm4flash main.bin
Found ICDI device with serial: 0F0006C6
ICDI version: 12245
I wonder what the makefile entry - really should be  (seems like the new tivaware rel notes says they abandoned the BLIZZARD stuff)
CFLAGS += -DTARGET_IS_BLIZZARD_RA1
/Bingo
Online mkissin
« Reply #51 on: March 20, 2014, 07:26:29 am »
I think they're TARGET_IS_SNOWFLAKE_RA0
Offline bingo600
« Reply #52 on: March 20, 2014, 05:12:19 pm »
I was told this on the StellarisTI forum
It's TARGET_IS_TM4C129_RA1 for the new TivaWare 2.1, or the later releases of TivaWare 2.0 it's TARGET_IS_SNOWFLAKE_RA0
So i guess you're right for tivaware 2.0
/Bingo
Offline AndrejaKo
  • Country: cs
« Reply #53 on: March 21, 2014, 10:27:22 am »
I just got my Launchpad and here are my first impressions:
The build quality isn't the best and isn't as good as it was on launchpads from say a year ago. It came covered in flux (but nothing a few minutes with alcohol couldn't fix) and has several bad-looking solder joints. The device/OTG USB connector has been soldered at an angle an doesn't inspire much confidence in me.
The Booster pack headers are a bit different than on original Tiva Launchpad. They are now much thicker and less flexible and give the feeling of standard pinheaders. This is good news for me, since I usually use the exposed pins to connect scope probes and pins on 123 Launchpad tend to bend.
For the bottom breadboard holes, I plan to try to use a saw to cut an angled pinheader into two pieces. I'll report the results as soon as I can.
