Hello guys
Sorry if this is a stupid question!
I want to generate a wave form using the output compare feature on Stm32F407 on timer3, but I'm a bit confused which pin do I have to choose, because if I look in the alternate function table, I find that TIM3_CH1 is assigned to the following pins:
-PA6
-PB4
-PC6
So, my question, can I use either one of them? Also, they don't mention if these channels are inputs or outputs! So, I guess I have to use the MODER register to set them there?
Thank you in advance
