I'm figuring the same length, but one option has a via and the other doesn't. When I say same length, I'm assuming the 1.2-1.6mm of 8 layer board is accounted for there. So, given the same trace lengths the one without the via is surely better. I just can't get and understanding for where on the list of more important things this is.
Calculate it and it might give you a better perspective.
This is very low on the list of important EMI issues and probably the board design in general.
Is it not obvious I do not know how to do that?
OK, I'll try.... And I could be WAY WAY off here... using a calculator, a blog, and AI I figured that:
Without vias for a .2mm trace, 1oz copper, 1.6mm board, ground plane is .1mm away from both the bottom and top planes, 2mm trace length, that it's 35.94nH of inductance. Then adding a via is 1.6nH. So.... 4.5% difference?
Is that remotely correct and what I would be looking for in negative effects here?
