Author Topic: STM32CubeMX sprintf does not work with float  (Read 4977 times)
Offline ebclrTopic starter
« on: September 23, 2022, 10:17:21 am »
I have those 2 similar routines, one to write an integer to the LCD and the other to write a float,  the integer ones work perfectly but the very similar one for float does not work, I'm guessing that sprintf fails for a float on stm32cubemx compiler, any tips on that?
void writeInteger(LiquidCrystal *lcd, int valueToBedisplayed, uint8_t MaxLenghtOfDigitis)
   char StringValue[MaxLenghtOfDigitis];
   sprintf(StringValue, "%d", valueToBedisplayed );
   size_t Lengh = strlen(StringValue);
   for (uint8_t i = 0; i < Lengh; i++){
      write(lcd ,*(StringValue+i));
void writefloat(LiquidCrystal *lcd, float floatToBeDisplayed, uint8_t MaxLenghtOfDigitis)
   char StringValue[MaxLenghtOfDigitis+2];
   sprintf(StringValue, "%f", floatToBeDisplayed );
Offline langwadt
Re: STM32CubeMX sprintf does not work with float
« Reply #1 on: September 23, 2022, 10:21:59 am »
mcu settings:  -u _printf_float
Offline peter-h
« Reply #2 on: September 23, 2022, 11:10:17 am »
Have a read around here
https://www.eevblog.com/forum/microcontrollers/is-st-cube-ide-a-piece-of-buggy-crap/msg4363183/#msg4363183
You can have lots of fun with the Newlib libc.a library and it's duff mutexes, its use of the heap, etc :)
In the end I replaced it with an open source one - all in the thread and here
https://www.eevblog.com/forum/programming/best-thread-safe-printf-and-why-does-printf-need-the-heap-for-f-etc/msg4325479/#msg4325479
Offline DavidAlfa
« Reply #3 on: September 23, 2022, 10:15:38 pm »
I remember some option in the compiler/linker whatever settings to enable floats in printf
Offline DavidAlfa
« Reply #4 on: September 24, 2022, 09:01:49 am »
As I said, here it is
Offline peter-h
« Reply #5 on: September 24, 2022, 10:53:01 am »
That gives you the crappy Newlib library from 1990 which uses empty mutex function stubs, and the heap (which also has empty mutex function stubs) :)
Best to follow the instructions I posted and replace the printf family entirely.
But if not using an RTOS and the program is just simple, it doesn't matter. You do need to set up a heap though (_sbrk etc).
