These F1/F2/L1 chips from STM have very similar peripherals.
The F103 is a faster and feature-rich version of F102, although F103 is cheaper in retail, it may not be in volume.
For development, I'd suggest picking a 512kB flash/64kB SRAM in LQFP100 or higher, for release you can pick anything that barely matches the requirements (down to 16kB QFN36). Mind these 72MHz chips are optimized for speed so jumping from coremark=11 for AVR8 to coremark=108 of F103 may not be what you expect (GCC).
Now the differences..
These chips use 3,3V nominal voltage, some IOs can operate up to Vcc+4V, around 8V max in open drain mode (I think they refer those as "5V tolerant"). This "feature" means that internally these 8V IOs do not have the upper clamping diodes. So, if you apply 12V through 4k7 resistor to an IO of AVR8 then nothing spectacular happens, IO is driven up to Vcc+0,7V and upper clamping diode limits the voltage.
The problem is that same experiment should fry the 8V IO on STM32.
Now, not all STM32 IOs are 8V compatible. Some are just regular IOs with both clamping diodes. Here injecting current won't damage the chip "if you limit the current to the one specified in maximal ratings of course " but can ruin ADC readings of the uC.
As of the toolchains, if you pick the IDE with wizarding (like uVision or CooIDE) then the setup is similar to the one with AVRStudio. Just name the project and:
int main void(){..... return 0;}
However, if you decide to pick a bare metal route, then it is same as with bare metal AVR8 and you have to provide your own linker, startup code, IRQs etc. If you never wrote startup code and/or linker scirpt for AVR8 then most likely writing one for STM32 is going to discourage you (even configuring a clock tree can ruin your day).
