Author Topic: STM32F103C8 diagnostic bootable binary freely available  (Read 15543 times)
Offline techman-001Topic starter
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
« on: December 15, 2019, 11:34:55 am »
Hi All,
Announcing a bootable 52.6kB diagnostic test kit binary for the STM32F103C8 such as used in the "Blue Pill Board". The size is under 64kB so that it can be flashed by OpenOCD to a MCU claiming only 64kB of Flash in the "Flash size register".
The purpose of this kit is to physically test the "hidden" 64kB second Flash block present on many of these chips and determine if it exists and if it is reliable. It does this by flashing all the bits from one to zero and back again.
Download here: https://sourceforge.net/projects/mecrisp-stellaris-folkdoc/files/STM32F103C8-DIAGNOSTICS.bin/download
Usage
1.   Flash the STM32F103C8-DIAGNOSTICS.bin image to your board with OpenOCD or whatever you normally use.
2.   Plug in a USB cable to the “Blue Pill” board and run a serial terminal program on your PC. This will also power the board.
3.   Enter “?” at the prompt to obtain the menu.
Menu
Enter ? for the menu
m - Menu; STM32F103R8 Test Kit
i - Device ID
b - Device Reported Flash Size in Bytes
t - TEST second 64kB Flash Memory block: 0x10000 - 0x1FFFF
d - Dump second 64kB Flash Memory block: 0x10000 - 0x1FFFF
e - Dump first  64kB Flash Memory block: 0x00000 - 0x10000
a - Author
l - License
q - Quit
Developed on a STM32F103C8 board (with the "hidden" second 64kB Flash block present) which is identical to a "Blue Pill", so it should work on all such boards.
Note: there are only three Block erasures and two Block flashes when this test is run, so the Flash wear is negligible.
A successful test looks like this:
Testing 64kB Flash block: 0x10000 - 0x1FFFF
Erasing
Flash with 1010101010101010 (0xAA)
Testing for 0xAA - OK
Erasing
Flash with 0101010101010101 (0x55)
Testing for 0x55 - OK
Erasing
~~~~~ ALL TESTS PASSED ~~~~~
More information here: https://mecrisp-stellaris-folkdoc.sourceforge.io/stm32f103c8-diags.html#stm32f103c8-diagnostics
« Last Edit: December 15, 2019, 11:48:15 am by techman-001 »
The following users thanked this post: BravoV, bingo600, thm_w, ebclr, coromonadalix, knapik, I wanted a rude username
Offline fmkit
  • Country: il
Re: STM32F103C8 diagnostic bootable binary freely available
« Reply #1 on: December 15, 2019, 11:48:17 am »
 have you found a real 64kb C8 ?  out of 20 chips I tried all were 128kb
« Reply #2 on: December 15, 2019, 12:14:20 pm »
Not yet. I only have 10 boards all with 128kB and 20 new 64 pin flatpack chips but with no ZIFF socket I won't be trying them for a while.
The reason I made the test image is because no one is sure whether the extra 64kB is ok or not, i.e. whether there may be a bad bit in there or not.
This test will find a bad bit.
Offline ebclr
« Reply #3 on: December 15, 2019, 01:02:45 pm »
Did you make this bin in FORTH ?
Offline fmkit
  • Country: il
« Reply #4 on: December 15, 2019, 04:11:26 pm »
Flash size can be read at  0x1FFF F7E0
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #5 on: December 15, 2019, 04:41:01 pm »
I am using minicom on a Raspberry PI. First thing is to change the serial port from /dev/ttyUSB0 to /dev/ttyACM0.
Testing a CPU marked STM32F103C8T6:
stm32id
Die xy coords: 107806545
Wafer Number: 73
Lot_num ascii encoded  [23:0]: 0x00485478  | H T x
Lot_num ascii encoded [55:24]: 0x67244344  | g $ C D
Flash Size Register = 65536 Bytes
Erasing
Erasing
Erasing
My first test, though was accidentally a CKS CS32F103C8T6 that an ebay seller sold as the ST part.
EDIT: The part number is actually CKS32F103C8T6.
stm32id
Die xy coords: 16917299
Wafer Number: 50
Lot_num ascii encoded  [23:0]: 0x004D3712  | M 7 .
Lot_num ascii encoded [55:24]: 0x004E4B43  | . N K C
Erasing
FAILTEST: $10000  Data = $8C
FAILTEST: $10001  Data = $03
... all the way to
FAILTEST: $1CDE5  Data = $BD
FAILTEST: $1CDE6  Data = $00
FAILTEST: $1CDE7  Data = $00
blank check FAILTEST
It looks like the binary I just flashed. Apparently this chip reads the second 64K from the first.
« Last Edit: December 15, 2019, 06:48:28 pm by rhodges »
Currently developing embedded RISC-V. Recently STM32 and STM8. All are excellent choices. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
« Reply #6 on: December 15, 2019, 05:41:04 pm »
Yes I did.The binary is a complete Mecrisp-Stellaris Cortex-M3 Forth.
The following users thanked this post: ebclr
« Reply #7 on: December 15, 2019, 06:07:12 pm »
stm32id
Wafer Number: 73
Erasing
Erasing
Erasing
stm32id
Wafer Number: 50
Erasing
... all the way to
Thanks for the feedback, I wasn't able to verify proper bad chip detection with a bad chip because 'unfortunately' mine are all good ;-)
You're right, the bootable binary finishes at 0xCDE7 and is the same data as you have listed above.
Did you enable the Minicom log then press "d" to generate a dump of the binary data at 0x10000 - 0x1FFFF ?
Offline rhodges
« Reply #8 on: December 15, 2019, 06:53:46 pm »
Yes. At the end, I saw the GPL text and some strings from your test code.
Offline bingo600
« Reply #9 on: December 15, 2019, 09:12:48 pm »
@techman-001
Nice test  :-+
And apparently "One bites the dust".
I was under the impression, that even those CKS had 2 x 64K.
Now to avoid those bluepill's on Ali/*bay
Thnx
/Bingo
« Reply #10 on: December 15, 2019, 10:36:50 pm »
Detective RHodges is on the job!
« Reply #11 on: December 15, 2019, 10:42:25 pm »
@techman-001
Nice test  :-+
Thnx
/Bingo
You're responsible anyway, for giving me the nudge to look into this.
Bluepills are like a box of chocolates .... but then one doesn't get many chocolates for under $2 these days.
« Reply #12 on: December 25, 2019, 10:00:25 am »
Now with a Xmas Day video  :popcorn:
"Did Santa bring your Blue Pill Board a free 64kB for Xmas ?"
https://youtu.be/xpTvd1Zhe0U
Offline Doctorandus_P
« Reply #13 on: January 08, 2020, 12:13:02 am »
I did not spend much time on this, as I'm not interested in binary blobs, but still had a look...
Then I saw it was soe FORTH thing, and that done it, closed the website.
I don't have anything against FORTH, but I am simply not interested in learning yet another language.
Offline BravoV
  • +++ ATH1
« Reply #14 on: January 14, 2020, 11:59:31 am »
Mr.Porter,
Reporting my BluePill, the one with the printed "RESRT" label for the RESET button.  :palm:
From this thread -> Cheap Bluepill, very likely it has fake STM32 right ?
Using your latest STM32F103R8 Test Kit v1.2 24Dec2019 version.
Result from "i" command :
stm32id
Die xy coords: 16985357
Wafer Number: 45
Lot_num ascii encoded  [23:0]: 0x004D3812  | M 8 .
Result from "b" command :
Flash Size Register = 131072 Bytes
Result from "t" command :
Erasing
Erasing
Erasing
« Last Edit: January 14, 2020, 12:16:18 pm by BravoV »
« Reply #15 on: January 14, 2020, 01:17:13 pm »
Mr.Porter,
stm32id
Wafer Number: 45
Erasing
Erasing
Erasing
G'day BravoV,
Thanks for the feedback.
I suspect that your chip may be a Chinese clone, the  "CKS32F103C8T6" because it uses hexadecimal for the LOT numbers, the same as yours and has 131072 bytes of ram. Finally your chip "Die xy coords" are very similar to Chinese clone #1 below.
STM32F103CX don't use hexadecimal for the LOT numbers.
Can you see any part numbers on your chips ? Either way they report 131072 bytes of flash and also test ok, that means they do have 131072 bytes of working flash as reported.
Here are two user submissions for CKS32F103C8T6's
Chinese clone #1
CKS32F103C8T6
Die xy coords: 16985099
Wafer Number: 42
Lot_num ascii encoded  [23:0]: 0x004D3512  | M 5 .
Lot_num ascii encoded [55:24]: 0x004E4B31  | . N K 1
Free
FLASH.. TOTAL REPORTED: 131072 USED: 51200 FREE: 79872
Chinese clone #2
CKS32F103C8T6
Die xy coords: 276745
Wafer Number: 42
Cheers,
Terry
Offline BravoV
  • +++ ATH1
« Reply #16 on: January 15, 2020, 02:59:14 am »
The interesting comparison when reading the "Lot" number in ASCII form :
Your others CKS string
M5.
.NK1
While mine has
M8.
.NKC
Newer CKS revision maybe ?  :-//
Also remember "F" character at the label position, as its printed at the 1st line, instead of 2nd line.
PS : Btw, regarding my report & photos, feel free to use it as you want, like for your blog.  :-+
« Last Edit: January 15, 2020, 03:01:51 am by BravoV »
« Reply #17 on: January 15, 2020, 04:34:10 am »
M5.
.NK1
While mine has
M8.
.NKC
You can disregard the ASCII output because those dots are HEX numbers and discarded by my program. As they're just lot numbers there is no version information.
Ah yes, the position of the F could well be a clue the chip is fake.
Thanks, I will definitely use your data in my blog as it may help others with Blue Pills.
Offline BravoV
  • +++ ATH1
« Reply #18 on: January 15, 2020, 08:35:20 am »
And coincidentally  ::) ... on CKS, they have the same style too which put the "F" at the 1st line.
I've read somewhere, that counterfeiters nowadays also want their product can be identified, as they need it for traceabilities in the supply chain and distribution, as cosmetic/appearance can be made almost perfect now.
I guess the reset button label (RESRT) is also deliberately misspelled.  :-//
« Reply #19 on: January 29, 2020, 01:18:25 pm »
Hi All,
Usage
Menu
i - Device ID
a - Author
l - License
q - Quit
G'day,
So far there have been 78 downloads of this diagnostics program. My thanks to those who provided feedback and data  :-+
I'm about to release V2 which incorporates improvements and bug fixes.
Before I finish this release are there any changes or additions you would like to see to the menu to improve this free diagnostic program ?
Cheers ...
Offline Mecanix
  • Country: cc
« Reply #20 on: February 04, 2020, 10:01:36 pm »
Great script, looking forward V2.0
Offline eliocor
    • rhodiatoce
« Reply #21 on: February 05, 2020, 12:05:10 am »
will it be possible to compile a version with PB9 active?
It is needed to enable the USB port on Maple Mini clones: https://stm32-base.org/boards/STM32F103C8T6-Maple-Mini-Clone.html
« Reply #22 on: February 05, 2020, 01:57:33 am »
Absolutely, great idea!
I'll enable USB for the Blue Pill, Olimex-P103 and the Maple-Mini, all at the same time on the new STM32F103C8 Diagnostic V2.
Different Firmware won't be needed.
Offline GromBeestje
« Reply #23 on: February 05, 2020, 08:11:39 am »
Could you also include PC13, as you did on my custom build?
« Reply #24 on: February 05, 2020, 08:56:39 am »
It *would* be my pleasure but ...
Blue pills have their user LED at PC13, any suggestions how we might accommodate this in the one build ?
An option jumper  perhaps ?
« Last Edit: February 05, 2020, 08:59:08 am by techman-001 »
« Reply #25 on: February 05, 2020, 09:38:57 am »
Hi All,
Usage
Menu
i - Device ID
a - Author
l - License
q - Quit
Erasing
Erasing
Erasing
Hi All,
For those inquisitive souls among us ...
A gentle introduction to Forth via a PC13 LED Blinky for use with the STM32F103C8-DIAGNOSTICS.bin running on a generic Blue Pill Board.
The STM32F103C8-DIAGNOSTICS.bin is the perfect vehicle for this as it's a complete Forth system itself.
https://mecrisp-stellaris-folkdoc.sourceforge.io/bluepill-blinky.html#bluepill-blinky
No C pointers were harmed in the making of this program.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #26 on: February 05, 2020, 10:35:58 am »
1) To flash with the arduino/stm32duino toolchain using the serial port bootloader use:
stm32flash -w STM32F103C8-DIAGNOSTICS /dev/serialportxxxx
stm32flash is inside the Arduino/hardware/Arduino_STM32/tools/ folder, or here:
https://github.com/stm32duino/stm32flash
2) Upon reboot the serial port @ PA9/10 stops working and I can only connect through USB.
3) LED ON doesn't work. My LED is at pin PC13 (robotdyn black pill, standard blue pill)
  • Country: tr
« Reply #27 on: February 05, 2020, 10:52:50 am »
Ok, I'm a bit late buuut, here's my suggestion. Instead of i) and b) that report tiny bits of info each, leave a single i) that prints a longer chip report similar to what smt32flash does:
stm32flash -b 115200 /dev/cu.SLAB_USBtoUART
stm32flash Arduino_STM32_0.9
http://github.com/rogerclarkmelbourne/arduino_stm32
Interface serial_posix: 115200 8E1
Version      : 0x22
Option 1     : 0x00
Option 2     : 0x00
Device ID    : 0x0410 (Medium-density)
- RAM        : 20KiB  (512b reserved by bootloader)
- Flash      : 128KiB (sector size: 4x1024)
- Option RAM : 16b
- System RAM : 2KiB
« Last Edit: February 05, 2020, 11:05:23 am by GeorgeOfTheJungle »
Offline GromBeestje
« Reply #28 on: February 05, 2020, 11:01:19 am »
The board I will use is https://github.com/a-v-s/pcb_stm32XxxxCx_board
I have this solder bridge I can use to hard wire the pull up resistor to VCC, and put it back to PC13 afterwards.
I guess that would be the easiest for the moment.
Or can we make it auto-detect the board?  Upon boot, if you read PA12 as input, if it is high, the board has hard wired pull up, so it might be running on a Blue Pill, and PC13 can be selected as LED pin. if it is low, you have to pull it up by one of the pins PB9 or PC13. As we've identified the board not being a standard Blue Pill, this would be safe to do.
For now APM32, CS32, and GD32 have passed my initial tests to have at least some level of STM32F1 compatibility.
BLM32 and MM32 failed.  BLM offers no docs/libs. MM does.
« Reply #29 on: February 05, 2020, 12:03:54 pm »
2. It's USB OR PA9/10. USB is the default, but from USB you can enter "-usb" and it swaps to PA9/10.
3. Yeah led.on was for my own testing, I have to sort out how to handle different LED wiring yet.
« Reply #30 on: February 05, 2020, 12:09:56 pm »
Version      : 0x22
Option 1     : 0x00
Option 2     : 0x00
- Option RAM : 16b
- System RAM : 2KiB
Never too late George :)
V2 does a all in one report and even a optional XML output for, records and later DB entry and analysis.
V2 focuses on obtaining correct data for posterity!
The 'hidden' 64kB block test can't be run automatically as it will throw a exception on chips without it, so this test still needs to be manually selected.
« Reply #31 on: February 20, 2020, 10:04:49 am »
Hi All,
My new version of the diagnostics program, stm32fxx-diagnostics-v1.0.bin is now available, please see: https://mecrisp-stellaris-folkdoc.sourceforge.io/stm32f1xx-diagnostics.html#stm32f103xx-diagnostics
This is the new version of STM32F103C8-DIAGNOSTICS.bin which was my first exploratory program to explore what actual MCU was in any of the infamous Blue Pill boards. The Blue Pill suffered from many issues but the most serious was the use of 'fake' and 'compatible' non genuine STM32F103 chips.
The new stm32f103xx-diagnostics contains lessons learned from the above and adds new features such as :-
*  Attempts to tell if the MCU is a STM32F,CS32F or APM32F or a GB32F
*  Simpler, cleaner Main Menu
*  Extra Menu
*  Generates a XML dump of all the data with suggested unique filename. This can them be uploaded to a database to examine what chips and memory have been found. This can then be uploaded, see the "FAQ" for details.
*  Should work with the Maple Mini board
*  Halts nicely with a error message if the second 64kB Flash block fails
Plus the old capabilities:
 * Under 64kB in size so it can be loaded and run from any STM32F1xx class with 64kB Flash
 * Bootable
 * Creates a "Mecrisp STM32F10x Forth Serial Port, class 2/0, rev 2.00/2.00, " virtual serial port device on your PC
 * Dump the contents of the first 64kB Flash block
 * Dump the contents of the second 64kB Flash block
 * FAQ's, Credits, and Liucense are in the "Extra" menu
 * Serial can be connected to USART2 instead of USB.
The following users thanked this post: thm_w, GeorgeOfTheJungle
  • Country: tr
« Reply #32 on: February 20, 2020, 10:36:32 am »
upload your XML file to the URL or email it to me
The URL is:
* Why is there a XML dump ? << To build a database of genuine vs fake chips. Please upload yours to:
https://sourceforge.net/p/mecrisp-stellaris-folkdoc/discussion/general/thread/a0e1c385e8/#7dc0
« Reply #33 on: February 20, 2020, 12:13:40 pm »
The URL is:
Thanks, chip ID: 704FAE48 definitely looks like a genuine STM32F103C8 to me.
Somehow we have two 'external markings' selections, so that's my first bug to fix:
<stm32f103c8>1 </stm32f103c8>
<stm32f103cb>1 </stm32f103cb>
« Reply #34 on: February 20, 2020, 12:52:39 pm »
The URL is:
External markings bug fixed in V1.1 on the website: https://sourceforge.net/projects/mecrisp-stellaris-folkdoc/files/stm32fxx-diagnostics-v1.1.bin
  your data as a FILE, *not a picture* using the file name suggested in the dump to:
Offline eliocor
    • rhodiatoce
« Reply #35 on: February 26, 2020, 02:12:33 am »
Sorry to bother you, but I tried you binary file (v1.1) on several Maple Mini boards (various HW releases) but with no avail.
Windows does not recognize the USB device (not even a "faulty" USB device)
If needed I'm available to make some tests for you.
« Last Edit: February 26, 2020, 02:14:45 am by eliocor »
« Reply #36 on: February 26, 2020, 05:48:08 am »
It's no bother, I'm happy to get it working with other boards.
My information is that PB9 pulsed high enables USB on the Maple Mini, and this should be happening with my stm32fxx-diagnostics-v1.1.bin, the pulse is about 10 milliseconds wide.
If you have a scope or whatever can you check this is happening  and do you know if it's the right polarity ?
Offline eliocor
    • rhodiatoce
« Reply #37 on: March 14, 2020, 12:43:00 am »
Using some spare time* I made the tests you required: please take a look to the attached picture for more details.
cyan trace is Vcc: from 0 to 3.3V when the Maple Mini board is plugged into the USB socket
yellow trace is PBL: strobed for 1ms after about 68ms from Vcc going to 3.3V
zoom.png shows the USB enable (PB9) pulse.
To my knowledge (tested with a CDC device) you need to set PB9 to 0 (without pulsing it) to activate the communication with the PC.
If you put PB9 to 1 the device will disconnect from the PC.
I tested the Maple Mini with v1.3 of your utility.
 *) I live in Italy so I'm stranded at home....  :(
« Last Edit: March 14, 2020, 12:45:24 am by eliocor »
« Reply #38 on: March 23, 2020, 03:06:39 am »
I've just released V1.4 at https://sourceforge.net/projects/mecrisp-stellaris-folkdoc/files/stm32fxx-diagnostics-v1.4.bin
V1.4: Changed PB9 to permanent LOW for Maple Mini, menu is run from boot, Version number is automatically displayed in the menu.
Please let me know how it goes ?
Stay safe, sorry to hear about the Covid-19 dramas and high death rate in Italy, home of my Motoguzzi Griso.
Offline eliocor
    • rhodiatoce
« Reply #39 on: March 23, 2020, 07:22:04 am »
It works flawlessly!
I tested it on 6 Maple Mini: it seems they have original SM32F103CB micros.
I tried to upload the .XML files but I'm awaiting for posting moderation....
.      thanks
_          Elio.
« Reply #40 on: March 23, 2020, 09:27:49 am »
.      thanks
_          Elio.
Excellent news, thanks for the update  :-+
Offline roboticboyer
« Reply #41 on: July 15, 2020, 08:28:19 pm »
I'm trying a Blue Pill with a "compatible" STM32, probably a GD32F103 with your Diagnostic Tool
When I try all commands such as "t" the response is "t t not found" then "ok ok"
Only "?" responses with the menu
Do you know how to fix this issue?
Is something related to the GD32 chip itself?
Thank you
Gio
« Reply #42 on: July 16, 2020, 02:06:17 am »
Thank you
Gio
You enter "?" to run the menu, then entering "t" etc will work. You don't press enter after a menu command, it runs when you just press the key.
If you get "t t not found" or similar it means you entered a non menu key and it quit out of the menu, so youre actually in the Forth command line. Entering "?" restarts the menu.
I've made a new version which wont quit the menu so easily but have to do a few more tests yet, and then will upload it onto my site. I'll announce the new version here when it's ready.
« Reply #43 on: July 18, 2020, 07:19:36 am »
Thank You! :-+
Now I'm able to use your good tool with Arduino Serial Monitor => It's required only to select CR not NL+CR
My Blue Pill is inside a GD32F with 128k
« Reply #44 on: July 18, 2020, 09:25:02 am »
Thank You! :-+
Excellent, thank you for the update.
« Reply #45 on: October 22, 2020, 08:38:56 am »
Announcing my last update, stm32fxx-diagnostics-v1.5.bin
It's much the same as V1.4 but the menu is now robust and won't kick you out back to the command line when a non menu key is hit, including enter.
However if the test for a hidden second 64KB flash fails that may kick back to the cli so just enter 'menu' should that happen.
The binary, menu pictures and README are here: https://mecrisp-stellaris-folkdoc.sourceforge.io/stm32f1xx-diagnostics.html
Cheers,
Terry
The following users thanked this post: ralphrmartin, Jacon
