Hello i have problem with my code:
I use I2C to communicate with accelerometer.
In Code below you can see that i try do set registers in LSM303DLHC.
My problem is that program doesn't work when both init functions are called one after another.
When i test them separately init functions work as they should.
Any Ideas?
Code is here(in attachment files are .c and .h files):
#include <stdint.h>
#include "LSM303DLHC_REG_Protype_Code.h"
* @brief Read LSM303DLHC output register, and calculate the acceleration ACC=(1/SENSITIVITY)* (out_h*256+out_l)/16 (12 bit rappresentation)
* @param pnData: pointer to float buffer where to store data
* @retval None
#define ABS(x) (x < 0) ? (-x) : x
#define ENABLE 1
#define DISABLE 0
#define L3G_Sensitivity_250dps (float) 114.285f /*!< gyroscope sensitivity with 250 dps full scale [LSB/dps] */
#define L3G_Sensitivity_500dps (float) 57.1429f /*!< gyroscope sensitivity with 500 dps full scale [LSB/dps] */
#define L3G_Sensitivity_2000dps (float) 14.285f /*!< gyroscope sensitivity with 2000 dps full scale [LSB/dps] */
#define PI (float) 3.14159265f
#define LSM_Acc_Sensitivity_2g (float) 1.0f /*!< accelerometer sensitivity with 2 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_4g (float) 0.5f /*!< accelerometer sensitivity with 4 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_8g (float) 0.25f /*!< accelerometer sensitivity with 8 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_16g (float) 0.0834f /*!< accelerometer sensitivity with 12 g full scale [LSB/mg] */
void I2C1_TimeoutCallback(char errorCode) {
GPIOE_ODR.B15 = 1;
GPIOE_ODR.B14 = 0;
Delay_ms(500);
GPIOE_ODR.B15 = 0;
GPIOE_ODR.B14 = 1;
Delay_ms(500);
void LSM303DLHC_LowLevel_Init(){
GPIO_Alternate_Function_Enable(&_GPIO_MODULE_I2C1_PB67);
I2C1_Init_Advanced(100000,&_GPIO_MODULE_I2C1_PB67);
I2C1_SetTimeoutCallback(1000, I2C1_TimeoutCallback);
Delay_10us;
}// Init I2C1
uint16_t LSM303DLHC_Read(unsigned char DeviceAddr,unsigned char RegAddr,unsigned char* pBuffer, unsigned long NumByteToRead)
if(I2C1_Start() != 0){
I2C1_Write(DeviceAddr, &RegAddr, 1, END_MODE_RESTART); //Start condition to write to LSM303DLHC_CTRL_REG4_A register of LSM303DLHC
I2C1_Read(DeviceAddr, pBuffer, NumByteToRead, END_MODE_STOP); // Read from register @ RegAddr and save data to pBuffer
uint16_t LSM303DLHC_Write(unsigned char DeviceAddr, unsigned char RegAddr, unsigned char* pBuffer)
static unsigned char data_[2];
data_[0] = RegAddr;
data_[1] = *pBuffer;
I2C1_Write(DeviceAddr,data_, 2, END_MODE_STOP); //Start condition to write to LSM303DLHC_CTRL_REG4_A register of LSM303DLHC
void LSM303DLHC_MagInit()
uint8_t cra_regm = 0x00, crb_regm = 0x00, mr_regm = 0x00;
/*Configure the low level interface ---------------------------------------*/
//LSM303DLHC_LowLevel_Init();
/* Configure MEMS: temp and Data rate */
cra_regm |= (uint8_t) (LSM303DLHC_TEMPSENSOR_ENABLE | LSM303DLHC_ODR_30_HZ);
/* Configure MEMS: full Scale */
crb_regm |= (uint8_t) (LSM303DLHC_FS_8_1_GA);
/* Configure MEMS: working mode */
mr_regm |= (uint8_t) (LSM303DLHC_CONTINUOS_CONVERSION);
/* Write value to Mag MEMS CRA_REG regsister */
LSM303DLHC_Write(MAG_I2C_ADDRESS, LSM303DLHC_CRA_REG_M, &cra_regm);
/* Write value to Mag MEMS CRB_REG regsister */
LSM303DLHC_Write(MAG_I2C_ADDRESS, LSM303DLHC_CRB_REG_M, &crb_regm);
/* Write value to Mag MEMS MR_REG regsister */
LSM303DLHC_Write(MAG_I2C_ADDRESS, LSM303DLHC_MR_REG_M, &mr_regm);
void LSM303DLHC_AccInit()
uint8_t ctrl1 = 0x00, ctrl4 = 0x00;
/* Configure MEMS: data rate, power mode, full scale and axes */
ctrl1 |= (uint8_t) (LSM303DLHC_NORMAL_MODE | LSM303DLHC_ODR_50_HZ | LSM303DLHC_AXES_ENABLE);
ctrl4 |= (uint8_t) (LSM303DLHC_BlockUpdate_Continous |LSM303DLHC_FULLSCALE_2G | LSM303DLHC_BLE_LSB | LSM303DLHC_HR_ENABLE);
/* Write value to ACC MEMS CTRL_REG1 regsister */
LSM303DLHC_Write(ACC_I2C_ADDRESS, LSM303DLHC_CTRL_REG1_A, &ctrl1);
///* Write value to ACC MEMS CTRL_REG4 regsister */
LSM303DLHC_Write(ACC_I2C_ADDRESS, LSM303DLHC_CTRL_REG4_A, &ctrl4);
void main(){
LSM303DLHC_MagInit();
Delay_100ms;
LSM303DLHC_AccInit();
GPIO_Config(&GPIOE_BASE,_GPIO_PINMASK_HIGH,_GPIO_CFG_DIGITAL_OUTPUT);
while(1){
GPIOE_ODR.B15 = 1;
GPIOE_ODR.B14 = 1;
Delay_ms(500);
GPIOE_ODR.B15 = 0;
GPIOE_ODR.B14 = 0;
Delay_ms(500);
In attachments are pictures from logic analyser.
thank you, Best Regards
