Author Topic: STM32's HAL... Anything I can do to fix this outrageous bloat?! (pic)  (Read 21421 times)
Offline ralphd
    • Nerd Ralph
Re: STM32's HAL... Anything I can do to fix this outrageous bloat?! (pic)
« Reply #50 on: October 07, 2015, 09:43:45 pm »
I actually like it. You just create a flash array of those structs to configure the pins.
Easy to read, easy to switch, easy to diff.
Yes it takes a bit flash. But it would take an equal (if not larger) amount of flash if you write all the register configure lines separate.
But usually only a few of the registers need to be written.
Unthinking respect for authority is the greatest enemy of truth. Einstein
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #51 on: October 08, 2015, 05:48:41 am »
That depends if you want to set unused pins into a more energy efficient state.
