Author Topic: STM32F405RG USART DMA FIFO Error Problem  (Read 1334 times)
Offline syntax333Topic starter
« on: September 16, 2020, 12:46:45 pm »
Hello, I am trying to use DMA with USART to transmit and receive data to buffers in internal RAM.
I setup my DMA1_Stream4 as USART3_TX. However, after setting DMA control register, Peripheral address, memory address, number of data to transfer, Enabling DMA causes FEIF4 to set. I cannot transmit anything.
I shared my whole code below.
#include "main.h"
#include "SysClkConfiguration.h"
uint8_t USART3_Transmit_Buffer1[4] = {"Test"};
uint8_t USART3_Receive_Buffer[3];
void Initialization()
//----------RCC Configuration----------//
RCC->AHB1ENR |= RCC_AHB1ENR_GPIOCEN; //Enable GPIOC Clock
RCC->APB1ENR |= RCC_APB1ENR_USART3EN; //Enable USART Peripheral Clock
RCC->AHB1ENR |= RCC_AHB1ENR_DMA1EN; //Enable DMA1 Clock
//----------GPIO Configuration----------//
GPIOC->MODER |= (0b10<<GPIO_MODER_MODE10_Pos) | (0b10<<GPIO_MODER_MODE11_Pos); //Set PC11/10 as Alternate Function
GPIOC->OSPEEDR |= (0b10<<GPIO_OSPEEDR_OSPEED10_Pos) | (0b10<<GPIO_OSPEEDR_OSPEED10_Pos); //Set PC10/11 Output Speed as High Speed
GPIOC->AFR[1] |= (0b0111<<GPIO_AFRH_AFSEL10_Pos) | (0b0111<<GPIO_AFRH_AFSEL11_Pos); //Set PC10/11 as USART3 RX/TX
//----------USART Configuration----------//
USART3->CR1 &= ~(USART_CR1_UE); //USART Disabled
USART3->BRR = 0x0020; //Baudrate is set 2Mbps
USART3->CR1 |= USART_CR1_OVER8 | USART_CR1_TE | USART_CR1_RE; //Oversampling Mode, Transmit Enable, Receive Enable
USART3->CR3 |= USART_CR3_DMAT | USART_CR3_DMAR; //DMA Enable Transmitter, DMA Enable Receiver
//----------DMA Configuration----------//
DMA1_Stream1-> CR &= ~(DMA_SxCR_EN); //Disable DMA1_Stream1
// Channel 4 High Priority   Memory Inc. Circular Transmit Comp. Interrupt
DMA1_Stream1-> CR |= (4<<DMA_SxCR_CHSEL_Pos) | (0b10<<DMA_SxCR_PL_Pos) | DMA_SxCR_MINC | DMA_SxCR_CIRC | DMA_SxCR_TCIE;
DMA1_Stream1-> PAR  = (uint32_t) &USART3->DR;
DMA1_Stream1-> M0AR = (uint32_t) USART3_Receive_Buffer;
DMA1_Stream1-> NDTR = 3;
DMA1_Stream1-> CR |= DMA_SxCR_EN; //Enable DMA1_Stream1
DMA1_Stream4-> CR &= ~(DMA_SxCR_EN); //Disable DMA1_Stream4
// Channel 7 Medium Priority   Memory Inc. Memory-to-peripheral Transmit Comp. Interrupt
DMA1_Stream4-> CR |= (7<<DMA_SxCR_CHSEL_Pos) | (0b01<<DMA_SxCR_PL_Pos) | DMA_SxCR_MINC | (0b01<<DMA_SxCR_DIR_Pos) | DMA_SxCR_TCIE;
DMA1_Stream4-> PAR  = (uint32_t) &USART3->DR;
DMA1_Stream4-> M0AR = (uint32_t) USART3_Transmit_Buffer1;
DMA1_Stream4-> NDTR = 4;
DMA1_Stream4-> CR |= DMA_SxCR_EN; //Enable DMA1_Stream4 (Transmit Buffer through USART3)
//----------NVIC Configuration----------//
NVIC_EnableIRQ(DMA1_Stream1_IRQn); //Enable DMA1 Stream1
NVIC_EnableIRQ(DMA1_Stream4_IRQn); //Enable DMA1 Stream4
//----------Peripheral Activation----------//
USART3->CR1 |= USART_CR1_UE; //USART Enabled
void DummyDelay(uint32_t x)
while(x)
x--;
int main(void)
  HAL_Init();
  SystemClock_Config();
  Initialization();
  while (1)
  DummyDelay(1000000);
void DMA1_Stream1_IRQHandler()
if(DMA1->LISR & DMA_LISR_TCIF1)
DMA1->LIFCR |= DMA_LIFCR_CTCIF1; //Clear Transmission Complete Flag
void DMA1_Stream4_IRQHandler()
if(DMA1->HISR & DMA_HISR_TCIF4)
DMA1->HIFCR |= DMA_HIFCR_CTCIF4; //Clear Transmission Complete Flag
What could be the problem? What am I setting wrong?
