Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
STM32F407ZGT6 Based Dev. Board LXB407ZG-P1
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: STM32F407ZGT6 Based Dev. Board LXB407ZG-P1 (Read 415 times)
tpd
Contributor
Country:
on:
April 12, 2025, 09:33:44 am »
Is there any information on this dev. board? I bought it at Aliexpress (
https://www.aliexpress.com/item/1005008302886741.html?spm=a2g0o.order_list.order_list_main.130.25b31802iyzz6E#nav-specification
), but even the seller couldn't share anything useful.
Are there any datasheets, manuals, examples, anything on it?
Thanks
Logged
pcprogrammer
Super Contributor
Country:
Re: STM32F407ZGT6 Based Dev. Board LXB407ZG-P1
Reply #1 on:
April 12, 2025, 10:55:37 am »
Looks like a simple board with the bare minimum needed for running the MCU.
All you need to play with it is the information from ST:
https://www.st.com/en/microcontrollers-microprocessors/stm32f407zg.html
Under the documentation tab you can find the datasheet and the reference manual.
The bottom of the PCB shows the port pins on the silk screen. The double row 2.54mm 4x2 male pin header in the cutout gives access to the SWD interface, so programming and debugging can be done with a ST-link device. A cheap clone like this
https://nl.aliexpress.com/item/1005003575620794.html
will do.
To compile code all you need is the GNU compilers and a linker script. This repo seems to have example code for a STM32F407VG:
https://github.com/k-code/stm32f4-examples
Is the same core but has different number of IO pins.
Logged
FNIRSI 1013D Firmware repository
Hantek DSO2000 schematics
Anlogic AL3-10 FPGA reverse engineering
tpd
Contributor
Country:
Reply #2 on:
April 12, 2025, 11:07:36 am »
Thanks, damn Chinese, all their production is like this. It is a hell of job a beginner.
Logged
pcprogrammer
Super Contributor
Country:
Reply #3 on:
April 12, 2025, 11:10:08 am »
For a beginner there are simpler boards, so why did you choose this one?
Logged
tpd
Contributor
Country:
Reply #4 on:
April 12, 2025, 11:12:18 am »
I need it for pretty ambitious project, the simper ones can't manage it.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
