hi everyone.I am going to start a new project which it is a robot arm.I m gonna use stm32f429 and f4 for this project but I have little bit problem about servos.I choosed to mg996r servos and applied signal with this codes.
#include "main.h"
__IO uint16_t CCR1_Val;
__IO uint16_t CCR2_Val;
__IO uint16_t CCR3_Val;
__IO uint16_t CCR4_Val;
uint8_t PrescalerValue;
__IO uint16_t ADCConvertedValue[4];
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
ADC_InitTypeDef ADC_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
DMA_InitTypeDef DMA_InitStructure;
void TIM_Config(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Pin=(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_25MHz;
GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
GPIO_Init(GPIOC,&GPIO_InitStructure);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC,GPIO_PinSource6,GPIO_AF_TIM3);
GPIO_PinAFConfig(GPIOC,GPIO_PinSource7,GPIO_AF_TIM3);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource0,GPIO_AF_TIM3);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource1,GPIO_AF_TIM3);
void PWM_Config(void)
PrescalerValue=29;
TIM_TimeBaseInitStructure.TIM_Period=59999;
/*!< Specifies the period value to be loaded into the active
Auto-Reload Register at the next update event.
This parameter must be a number between 0x0000 and 0xFFFF. */
TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseInitStructure.TIM_ClockDivision=0;
TIM_TimeBaseInitStructure.TIM_Prescaler=PrescalerValue;
TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStructure);
TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
//TIM_OCInitStructure.TIM_Pulse=2656;
TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
TIM_OC1Init(TIM3,&TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM3,TIM_OCPreload_Enable);
//TIM_OCInitStructure.TIM_Pulse=CCR2_Val;
TIM_OC2Init(TIM3,&TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);
//TIM_OCInitStructure.TIM_Pulse=500;
TIM_OC3Init(TIM3,&TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM3,TIM_OCPreload_Enable);
TIM_OC4Init(TIM3,&TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3,TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3,ENABLE);
TIM_Cmd(TIM3,ENABLE);
void ADC_PortF_Config(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AN;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_0;//burayida iki kanala cikarttim.
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3|GPIO_Pin_2;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2,ENABLE);
/* DMA2 Stream0 channel2 configuration **************************************/
DMA_DeInit(DMA2_Stream4);
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue[0];
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = 4;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream4, &DMA_InitStructure);
DMA_Cmd(DMA2_Stream4, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
ADC_DeInit();
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;//burasi disable di enable yapayim
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 4;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 2, ADC_SampleTime_480Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 1, ADC_SampleTime_480Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 3, ADC_SampleTime_480Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 4, ADC_SampleTime_480Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
/* Enable ADC3 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC3 */
ADC_Cmd(ADC1, ENABLE);
ADC_SoftwareStartConv(ADC1);
void delay()
int a;
for (a = 0; a < 0x0000FFFF; a++) ;
int main(void)
SystemInit();
SystemCoreClockUpdate();
TIM_Config();
PWM_Config();
ADC_PortF_Config();
while(1)
CCR2_Val=(((ADCConvertedValue[0]*3000)/4096)+3000);
TIM3->CCR2=CCR2_Val;
CCR1_Val=(((ADCConvertedValue[1]*3000)/4096)+3000);
TIM3->CCR1=CCR1_Val;
CCR3_Val=(((ADCConvertedValue[2]*3000)/4096)+3000);
TIM3->CCR3=CCR3_Val;
CCR4_Val=(((ADCConvertedValue[3]*3000)/4096)+3000);
TIM3->CCR4=CCR4_Val;
when I check the signal wih an oscilloscope I give and excellent signal with peak max is a 3 v peak min is a 0v and a duty cycle change between 5% and %10. is 3 v can be a problem for triggering because I dissambly to servo but I couldnt find any datashhets about chip on the servos pcb.do you think it can be problem for the triggering of the chip.can anyone(who has a servo and 429i) try this codes.
