Author Topic: STM32F4Discovery USART problems  (Read 15149 times)
Offline skerdzius
« on: February 08, 2013, 07:24:00 pm »
i am using STM32F4Discovery board with CP2102 based USB-TTL converter to send data between PC and this board. so i connect RX, TX wires i use STM32F4xx_DSP_StdPeriph_Lib_V1.0.1 libraries and uVision Keil IDE. i send symbols, but in terminal i recieve a bunch of irrelevant symbols i am using example of USART code found on internet.
Offline ve7xen
    • VE7XEN Blog
Re: STM32F4Discovery USART problems
« Reply #1 on: February 08, 2013, 07:31:39 pm »
Looks like a baudrate mismatch. We can't do much to help without your code...
73 de VE7XEN
Offline enz
« Reply #2 on: February 08, 2013, 07:33:31 pm »
Wrong Baudrate?
Offline Bored@Work
« Reply #3 on: February 08, 2013, 08:07:45 pm »
Wrong baudrate. Send 'U's in an endless loop from the board. Use an oscilloscope to check the baud rate you are really sending.
Also check number of bits, stop bit length and parity bit (if any).
Offline skerdzius
« Reply #4 on: February 08, 2013, 08:10:11 pm »
i am aware of baudrate and i set it right.
#include <stm32f4xx.h>
#include <misc.h> // I recommend you have a look at these in the ST firmware folder
#include <stm32f4xx_usart.h> // under Libraries/STM32F4xx_StdPeriph_Driver/inc and src
#define MAX_STRLEN 12 // this is the maximum string length of our string in characters
volatile char received_string[MAX_STRLEN+1]; // this will hold the recieved string
void Delay(__IO uint32_t nCount) {
  while(nCount--) {
/* This funcion initializes the USART1 peripheral
 * Arguments: baudrate --> the baudrate at which the USART is
 *    supposed to operate
void init_USART1(uint32_t baudrate){
/* This is a concept that has to do with the libraries provided by ST
* to make development easier the have made up something similar to
* classes, called TypeDefs, which actually just define the common
* parameters that every peripheral needs to work correctly
* They make our life easier because we don't have to mess around with
* the low level stuff of setting bits in the correct registers
GPIO_InitTypeDef GPIO_InitStruct; // this is for the GPIO pins used as TX and RX
USART_InitTypeDef USART_InitStruct; // this is for the USART1 initilization
/* enable APB2 peripheral clock for USART1
* note that only USART1 and USART6 are connected to APB2
* the other USARTs are connected to APB1
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* enable the peripheral clock for the pins used by
* USART1, PB6 for TX and PB7 for RX
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
/* This sequence sets up the TX and RX pins
* so they work correctly with the USART1 peripheral
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; // Pins 6 (TX) and 7 (RX) are used
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; // the pins are configured as alternate function so the USART peripheral has access to them
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; // this defines the IO speed and has nothing to do with the baudrate!
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; // this defines the output type as push pull mode (as opposed to open drain)
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP; // this activates the pullup resistors on the IO pins
GPIO_Init(GPIOB, &GPIO_InitStruct); // now all the values are passed to the GPIO_Init() function which sets the GPIO registers
/* The RX and TX pins are now connected to their AF
* so that the USART1 can take over control of the
* pins
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_USART1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_USART1);
/* Now the USART_InitStruct is used to define the
* properties of USART1
USART_InitStruct.USART_BaudRate = baudrate; // the baudrate is set to the value we passed into this init function
USART_InitStruct.USART_WordLength = USART_WordLength_8b;// we want the data frame size to be 8 bits (standard)
USART_InitStruct.USART_StopBits = USART_StopBits_1; // we want 1 stop bit (standard)
USART_InitStruct.USART_Parity = USART_Parity_No; // we don't want a parity bit (standard)
USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // we don't want flow control (standard)
USART_InitStruct.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; // we want to enable the transmitter and the receiver
USART_Init(USART1, &USART_InitStruct); // again all the properties are passed to the USART_Init function which takes care of all the bit setting
/* Here the USART1 receive interrupt is enabled
* and the interrupt controller is configured
* to jump to the USART1_IRQHandler() function
* if the USART1 receive interrupt occurs
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); // enable the USART1 receive interrupt
// finally this enables the complete USART1 peripheral
USART_Cmd(USART1, ENABLE);
/* This function is used to transmit a string of characters via
 * the USART specified in USARTx.
 * It takes two arguments: USARTx --> can be any of the USARTs e.g. USART1, USART2 etc.
 *    (volatile) char *s is the string you want to send
 * Note: The string has to be passed to the function as a pointer because
 * the compiler doesn't know the 'string' data type. In standard
 * C a string is just an array of characters
 * Note 2: At the moment it takes a volatile char because the received_string variable
 *    declared as volatile char --> otherwise the compiler will spit out warnings
void USART_puts(USART_TypeDef* USARTx, volatile char *s){
while(*s){
// wait until data register is empty
while( !(USARTx->SR & 0x00000040) );
USART_SendData(USARTx, *s);
*s++;
int main(void) {
  init_USART1(9600); // initialize USART1 @ 9600 baud
  USART_puts(USART1, "hello world"); // just send a message to indicate that it works
  while (1)
comments are not mine, they are author's who posted this on internet
Offline Bored@Work
« Reply #5 on: February 08, 2013, 08:15:46 pm »
Then it would work. But it is your choice. You can start to measure or you can continue sitting there claiming everything is right
Offline skerdzius
« Reply #6 on: February 08, 2013, 08:28:10 pm »
baudrate in code is set at 9600. i set the same value in terminal. so what could possibly go wrong?  :o and sorry, but i don't have osciloscope :-//
Offline AndreasF
    • mind-dump.net
« Reply #7 on: February 08, 2013, 08:31:43 pm »
Code looks fine, but pin PB6 (your USART1_TX) is used as the I2C clock signal to the audio codec chip on the STM32F4Discovery, and maybe this causes some sort of interference.  :-//
I would try some of the other pins that aren't connected to anything else, eg. PA2 and PA3 (of USART2).
my random ramblings mind-dump.net
Offline enz
« Reply #8 on: February 08, 2013, 08:42:59 pm »
Maybe you should change this:
while(*s){
*s++;
to this
while(*s){
s++;
Hint: Note the removed asterisk before s++
Offline Skimask
« Reply #9 on: February 08, 2013, 08:51:49 pm »
Said nobody...ever...
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline skerdzius
« Reply #10 on: February 08, 2013, 09:15:19 pm »
i tried deleting asterix as told. everything compiled good but nothing changed. when i changed to USART2 nothing changed as well :S
Offline enz
« Reply #11 on: February 08, 2013, 09:22:35 pm »
Weird, it seems that there are a couple of errors coming together.
With the asterisk in you were incrementing the data you want to send, not the pointer. So this was an endless loop.
Without the asterisk you are now incrementing the pointer, there's no longer an endlees loop and the intended data will be send. Two errors less.
Next point:
Is the system clock set to the value the baudrate will be calculated from?
Offline CarlG
« Reply #12 on: February 08, 2013, 09:25:49 pm »
Have you verified that you're using the same PCLK and prescaler setting(s) as the USART code you're using requires?
Offline skerdzius
« Reply #13 on: February 09, 2013, 12:45:03 pm »
sorry, but i am not aware of these PCL prescaler or System clock settings. i don't know where to change them using standart peripheral libraries  :-// examples of usart code found on internet don't have any of these settings involved in them as i discovered  :-\
Offline gxti
« Reply #14 on: February 09, 2013, 02:43:16 pm »
Actually, no. In C, "++" binds more tightly than "*". So "*x++" is really "*(x++)" which is why you can do e.g ."*x++ = 0;". The before and after statements are equivalent.
Offline skerdzius
« Reply #15 on: February 09, 2013, 03:44:34 pm »
i found the formula in stm32f4xx_usart.h file, however i don't understand what are these parameters and how to change them in code  :-\
The baud rate is computed using the following formula:
                                            - IntegerDivider = ((PCLKx) / (8 * (OVR8+1) * (USART_InitStruct->USART_BaudRate)))
                                            - FractionalDivider = ((IntegerDivider - ((u32) IntegerDivider)) * 8 * (OVR8+1)) + 0.5
                                           Where OVR8 is the "oversampling by 8 mode" configuration bit in the CR1 register.
Online mrflibble
« Reply #16 on: February 09, 2013, 04:42:30 pm »
Here's a quick snippet from working code I normally use on that board. I think you can figure out how to change it from the current setting of 115200 baud to 9600 baud. ;-)
 * @brief Configure USART2 at 115200 baud, 8N1. Configure the GPIO pins (PA.2, PA.3) as push-pull.
 * @param None
void USART2_Config(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef  NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        // PA.2 = TX
        // PA.3 = RX
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_2 | GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
//      GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//      GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_USART2); // PA.2 = TX
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_USART2); // PA.3 = RX
//      USART_InitStructure.USART_BaudRate            = 9600;   // confirmed working. Remember to do: stty -F /dev/ttyUSB0 9600
        USART_InitStructure.USART_BaudRate            = 115200; // confirmed working. Remember to do: stty -F /dev/ttyUSB0 115200
        USART_InitStructure.USART_WordLength          = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits            = USART_StopBits_1;
        USART_InitStructure.USART_Parity              = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode                = USART_Mode_Tx | USART_Mode_Rx;
        USART_Init(USART2, &USART_InitStructure);
        USART_Cmd(USART2, ENABLE);
Online mrflibble
« Reply #17 on: February 09, 2013, 04:50:47 pm »
i am using STM32F4Discovery board with CP2102 based USB-TTL converter ...
I just noticed this... I also have a few of those. And some of those have the RX/TX labeled precisely the wrong way around. So better check and double check that CP2102 first.
Offline skerdzius
« Reply #18 on: February 09, 2013, 06:09:02 pm »
i can't explain this but i fix my connection like this:  i am using 115200 baudrate on my discovery board
init_USART1(115200); // initialize USART1 @ 115200 baud and on terminal i am listening at 38400 baudrate. then it works great  ;D thanks for help. maybe later i will find out a better solution, but it's enough  for now  :)
Offline AndreasF
    • mind-dump.net
« Reply #19 on: February 09, 2013, 08:49:01 pm »
Ahhha, I'm going to take a wild guess here then, that your HSE_VALUE define is wrong. As you may have noticed, 115200 is exactly 1/3 of 38400, so it seems that your STM32F4 thinks it's running three times faster than it actually is. This HSE_VALUE must be the frequency of the crystal on your board (on mine it's 8 Mhz). If it's not defined elsewhere the startup code will use the value stored in "stm32f4xx.h", which is 25000000 (or 25Mhz). As you notice, 25Mhz is approx. 3 times 8 Mhz.
I'm not familiar with the Keil IDE, but I'm guessing there is a way to set "predefined symbols" and that's where you should include a line like this "HSE_VALUE = 8000000" (or whatever crystal frequency you have on your board).
from "system_stm32f4xx.c":
  *         (**) HSE_VALUE is a constant defined in stm32f4xx.h file (default value
  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
  *              frequency of the crystal used. Otherwise, this function may
  *              have wrong result.
Online mrflibble
« Reply #20 on: February 09, 2013, 11:25:58 pm »
Yeah, that 25 MHz vs 8 MHz got me too when I just started. I grabbed some example code ... which of course just had to have the wrong PLL settings. You probably have it set to 25 MHz while you should have it set to 8 MHz.
Offline enz
« Reply #21 on: February 10, 2013, 10:08:19 am »
You are right, i missed the binding precedence.
But then the asterisk does not do anything and is needless.
Online mrflibble
« Reply #22 on: February 10, 2013, 11:58:56 am »
O_o
You don't use pointers very often, do you?
« Last Edit: February 10, 2013, 12:01:47 pm by mrflibble »
Offline Bored@Work
« Reply #23 on: February 10, 2013, 12:05:24 pm »
In other words, the baud rate is still wrong and was always wrong. And you are still in denial and call that a fix.
Online mrflibble
« Reply #24 on: February 10, 2013, 12:31:49 pm »
Yeah, but look on the bright side! Now the baud rate error is only about 4%. XD
Offline HackedFridgeMagnet
« Reply #25 on: February 10, 2013, 02:40:04 pm »
Sorry to be pedantic, but because I didn't know this I looked it up.
Apparently ++ and * have the same binding precedence but their group bind RL instead of LR.
Yeah yeah, which effectively means ++ has the higher binding precedence.
Offline enz
« Reply #26 on: February 10, 2013, 02:49:31 pm »
O_o
Of course i do.
Maybe you can explain what the asterisk would do exactly (and why they would be neccessary) in the following two statements:
1. *x++;
2. *(x++);
Regards,
Martin
Online mrflibble
« Reply #27 on: February 10, 2013, 03:46:13 pm »
I was replying to this particular quote. As in the combination of "*x++ = 0;" and "But then the asterisk does not do anything and is needless.". I was not replying to what you may or may not have been thinking while you were writing that. ;-)
But from your question I see what you meant to say.
1. *x++;
2. *(x++);
As for the answer, that would depend on how naive the compiler is, and what optimizations and such. In general I would expect those to just increment the x pointer. In fully pedantic mode, and on a platform where a memory access also performs a particular operation (memory mapped control register or whatnot) that cannot be optimized away, you could also expect it to do: 1) access memory at location x and then 2) increment x pointer.
Offline enz
« Reply #28 on: February 10, 2013, 03:56:47 pm »
Ah, now that was the misunderstanding. I was only referring to the original code from the OP (where there is no assignement), not to the "*x++ = 0;" example.
In the original code (*x++;) there is no need for the asterisk. In fact, it leads to false understanding what should be achieved with this statement and should be removed.
Online mrflibble
« Reply #29 on: February 10, 2013, 10:34:03 pm »
For extra confuzlement you could do "++*x++";. ;)
Offline enz
« Reply #30 on: February 11, 2013, 07:48:10 am »
Nice try. But i think it may not be enough for getting acknowledged by the obfuscated c aficionados.  ;)
Offline skerdzius
« Reply #31 on: February 15, 2013, 08:21:39 pm »
so i found out what was my problem. and it's rather shame for me :) i was using STM32F4xx_DSP_StdPeriph_Lib_V1.0.1 for all my projects, but all clocks, and settings were for STM32_eval board, and i am usint STM32F4Discovery. so i downloaded STM32F4-Discovery_FW_V1.1.0 edited project a bit, and now program is running as it's supposed to do. so happy now  ^-^
Offline ericksantosjaquez
« Reply #32 on: December 01, 2013, 01:41:42 am »
Where you find the correct template?
Online mrflibble
« Reply #33 on: December 02, 2013, 11:07:37 am »
If you read the previous posts you'll find code snippets by various posters.
