Author Topic: LPC4337 Won't debug most times!!! |O |O |O |O  (Read 1445 times)
Offline ali_asadzadehTopic starter
« on: November 20, 2017, 02:57:42 pm »
I have a board that I can program all the times and the program works fine, but most of the times I can not debug the code! |O |O some times I can debug the board  :) I had to be able to debug the board to be able to continue to develop the software, do you have any Idea what might be wrong? I have j-link and ulink2, and have similar issues with both of them
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline ehughes
Re: LPC4337 Won't debug most times!!! |O |O |O |O
« Reply #1 on: November 27, 2017, 03:32:09 am »
Can you share your schematic?
What is your tool chain?
Are you trying to debug the M4 or M0 core?
« Reply #2 on: November 27, 2017, 06:17:40 am »
The problem is now solved! ;)
the problem was that the Keil project file was corrupted in a very weird situation that It could program the chip, but not debug it!!! I simply create another project and Import all the project files :D
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: November 27, 2017, 08:21:46 am »
What version of uVision are you using?
« Reply #4 on: November 27, 2017, 10:38:48 am »
V5.24a
