@woofy
Thank you for the answer. As I mentioned earlier, my PCB has already been ordered, so I cannot add anything else.
For timekeeping, this is supposed to work normally. A battery has been placed on the Vbat pin of the RTC. However, I have the impression that without a crystal, I am in trouble; I suppose that the oscillation will not occur, and therefore my battery will be of no use.
For accuracy, I might be able to tinker with something less than ideal to salvage what I can, but it won't be clean, that's for sure, and it won't be much more precise, ironic for a clock, haha (my project).
You mentioned that I didn't provide the frequency, so I'm not sure I understood, so I will list them all here:
Input frequency to the RTC: 32.768 kHz
Internal PIC frequency: 4 MHz
Frequency of my stupidity: at least four times a day.
Sorry if I'm not specific with the terminology; I'm not a native English speaker.
