Author Topic: 2D Array in Arduino  (Read 4019 times)
Offline tiofilo75Topic starter
2D Array in Arduino
« on: September 11, 2013, 05:20:47 pm »
I am trying to print a 2D array but for some reason when I print an element higher than 0x7F the serial print appears to overflow. Here is an example:
 I define my array as :
unsigned int BANK[4][2]={{0x00,0x70},{0x01,0x85},{0x01,0x85},{0x00,0xe0}};
if I do a serial print of the second element of each array I will get the following:
70
FFFFFF85
FFFFFF85
FFFFFFE0
I don't know what is going on, why do I get the FFFFFF?  Can anyone please shed some light. Thanks.
Offline dannyf
Re: 2D Array in Arduino
« Reply #1 on: September 11, 2013, 06:18:49 pm »
they are being promoted to signed long.
Offline andersm
« Reply #2 on: September 11, 2013, 06:20:32 pm »
It looks like somewhere the numbers are being interpreted as signed 8-bit numbers, which are then being extended to 32-bit numbers.
