Author Topic: arduino text to o-scope decode  (Read 774 times)
Offline cyberwaspTopic starter
« on: February 07, 2020, 02:44:04 am »
Can someone point me to a sketch that I can use to send text to an O-scope. I'd like to test the SDS1202X-E scopes decode function. I ran across a youtube demo awhile ago and now I can't find it.TIA
« Last Edit: February 07, 2020, 02:54:45 am by cyberwasp »
Offline Ian.M
Re: arduino text to o-scope decode
« Reply #1 on: February 07, 2020, 07:13:49 am »
Assuming an ATmega328P based Arduino, any sketch that outputs text to the serial console will do.  e.g. Examples: 04.Communication: ASCIITable
Probe D1 (TX).  Note the output will be a logic level serial signal, which is inverted with respect to a true RS232 serial signal
The following users thanked this post: cyberwasp
