Author Topic: Substituting a uC (NXP Kinetis K60)  (Read 685 times)
Offline Jean_valjeanTopic starter
« on: April 12, 2022, 07:36:51 am »
Dear colleagues,
Does someone of You experience by substituting a uC in an existing product? What are Your experiences in this activity?
Concretely, I am trying to find a replacement for MK60DX256VMD10 from NXP. Just because it is out of stock everywhere and despite this anomaly we'd like to produce and sell our products.
The ideal solution would be (just my sweet dream, I'm afraid) to find something in the same package which is pinout - compatible and the same source code compiles without any bottleneck. (and then I wake up ... )
The second best is a code- and peripheral compatible uC which requires either a new board or an adapter-board to fit the pins.
Do You have any such experience? Are there proven method to do this?
(This is the same issue like the one in topic "Testing BGA uC before use", just another plan to solve the issue somehow.)
Offline luiHS
Re: Substituting a uC (NXP Kinetis K60)
« Reply #1 on: April 12, 2022, 11:42:00 am »
Only another microcontroller from the same manufacturer and family could have the same pinout and be compatible with the microcontroller's peripherals. The problem is that if that reference is not in stock, probably no other will be, due to the current world crisis of semiconductors.
I have replaced Kinetis MK66 LQFP144 with RT1064 BGA, both from NXP although from very different families, they only share that they are both ARM and use the same MCUXpresso IDE. The changes to be made in the source code were not many because the application was not very complex either, it only needed one UART and a few GPIOs with interrupts.
Now I think it's too late to be able to buy a 32-bit microcontroller in quantity to market a product. Maybe some LPCs, but no Kinetis or NXP i.MX are in stock. I bought the RT1064 and STM32H747 in quantity when the crisis began, and thus I was able to get enough to be able to work, but now it is impossible, there is nothing in stock.
