I've created a schematic. It is simple - but since I am not a HW person, I'd appreciate comments / feedback on it.
- Pin VDDA / VREF+ left unconnected - is that OK?
- only 1 uF decoupling cap per VDD pin, is that OK?
- Those current limiting resistors per LED, do I really need them if I plan to lit LEDs for like 3 seconds only, a couple of times a day?
- Thought a lot about USB connector, and since I plan to program baremetal, I have little idea about how it will work out. Ideally I could program the thing from using the USB connector, but I guess that needs a bootloader installed, so how then to bootstrap the chip? So for now I broke out UART and SWD as 2.54 inch spaced pin holes, to make sure I have options w.r.t. programming. I plan to stick a short female header for those, no idea about better connector options.
