Author Topic: Superscalar 68000, have you seen the Apollo core ? What do you think about ?  (Read 48791 times)
Offline legacyTopic starter
APOLLO CPU
The Apollo CPU is a modern CISC CPU design. Apollo is code compatible with the Motorola M68K and ColdFire families. The CPU is fully pipelined and superscalar supporting execution of up to 2 integer instructions per cycle. The CPU features two address calculation engines and two integer execution engines.
The size efficient variable length instruction encoding provides market leading code density and optimal cache utilization.
The CPU features a full internal Harvard architecture with separate multiway data and instruction caches. The instruction and data caches are designed to support concurrent instruction fetch, operand read, and operand write references on every clock. The operand data cache permits simultaneous read and write access each clock. The caches come with write combining, as well as memory stream detection and automatic memory prefetching. The combination of these features enables the core to be very efficient in memory and data manipulation tasks.
The branch prediction and branch folding makes the core ideally suited for execution of control flow code.
Optionally, a fully pipelined, double precision FPU is available to be included in the Core.
The Core is fully written in VHDL and can also be synthesized to be used in an FPGA device. When synthesized in an FPGA, the core offers a good combination of moderate FPGA space consumption and excellent performance. The core can reach up to 200 MHz / 400 Mips in consumer type Cyclone FPGA, and up to 400 MHz / 800 Mips in enterprise type FPGA. Clock by clock the core performs very good and scores in many benchmarks better than several ColdFire, ARM and PowerPC cores on a clock by clock comparison.
Features
  • Fully User-Code Compatible with MC68000
  • Superscalar Implementation of M68000 Architecture
  • Dual Integer Instruction Execution Improves Performance
  • Branch Cache Reduces Branches to Zero Cycles
  • Separate Data and Instruction Caches
  • Full Harvard Architecture allows Simultaneous Access to both caches
  • Data Cache allows Read and Write Access on Each Clock
  • Bus Snooping
  • 32bit Address bus
  • Optimized to Achieve Very High Performance Using DDR DRAM Memory
  • 128 bit Deep Store Buffer and One Deep Push Buffer to Maximize Write Bandwidth
  • Automatic memory stream detection and prefetching
  • Several memory loads can be held in flight in parallel to maximize bandwidth
for more info, see here the apollo-core project
personally i do not trust it is really possible, perhaps not for hobby purposes  :-//
guys, what do you think about ?
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
Or use a $10 ARM cored chip which has a huge support ecosystem? People do seem to get carried away with the "because we can" side of things.
Offline paulie
68k was Von Neumann, definitely not Harvard. How does that work?
I will say that those who do actual programming (aka assembly, aka Real Men) would find 68k a breath of fresh air compared to ARM.
Online amyk
They're talking about the cache: http://en.wikipedia.org/wiki/Modified_Harvard_architecture#Split_cache_architecture
it's a common approach in fpga, in order not to stall the fetch and the Load/Store stage
don't worry about that, it's just an implementation detail, it doesn't matter with the ISA, which is 68000
this soft core could be funny for things like "Amiga/Classic"
Offline paulie
Hmmmm... Not really being an fpga freak I didn't realize MCU can "go both ways". Nice thing about this site... you learn something just about every day.
Offline Rasz
    • My random blog.
400MHz is inside $1K virtex
100-200MHz is inside $100 cyclone
it was made with amiga accelerator "market"  in mind (that is ~100 people running sysinfo) so you can forget about it, it will never see the light of day. Authors probably hope to get a job offer at IBM (HAHA good luck, IBM is getting rid of its chip business at the moment).
Reminds me of http://www.majsta.com , that dude supposedly  joined 'apollo team' whatever that means.
yes, it's unbelievable story, unbelievable project: see TINA
personally i do not trust it will never exist !
that diagram was discussed 1 year ago, and it is still under discussion  :palm:
the same happens to the superscalar 68000 core :palm: :palm:
Offline chickenHeadKnob
The choice to call this new soft-core "Apollo" or "68020" is very confusing, if that are the names they choose. Back in the day, when the 68020 was a real part number from Motorola, Mentor Graphics (the chip CAD/EDA company), was selling a line of work stations called Apollo. That line used 68020 processors. Worse yet Mentor Graphics implemented a CPU board with a 68020 simulated with PAL's and other small scale integrated parts because they couldn't get real 68020 in time, I think Motorola was having trouble producing or delayed at the time. That emulated 68020 CPU board was a mess of bodge wires and revisions, a real banjo board. Needed constant repair :palm:
Offline theoldwizard1
First, anyone who is "in to" specific implementation of a given Instruction Set Architecture should have already read Computer Architecture, Fifth Edition: A Quantitative Approach.  I think mine is 1st edition, but it is all still relative.
Harrvard versus Von Neumann IS an implementation detail, but it is an extremely important detail !
The biggest performance "bottleneck" is accessing memory for instructions and data.  For years, bigger caches, and multiple layer caches have been the solution.  Pretty much all Harvard architecture machine are "folded" back into a single address space.
IMHO, the best way to improve performance is to improve the CPU to memory (cache or main memory) access and the fastest way to do this is wider buses.  IIRC, the Digital Equipment Corporation Alpha architecture chips used a 256 bit wide bus.  Of course this causes all sorts of other issues.
I am a bit surprised that this is an implementation of the full M68K instead of the Coldfire.  The Coldfire was designed for small size and performance.
The last M68k chip, the 68060, had many interesting features.  Fast instruction decoding and parallel Effective Address calculation.
« Last Edit: December 25, 2014, 12:22:05 am by theoldwizard1 »
Online nctnico
I very much doubt they can get a core to run at >400MHz inside an FPGA. Sure FPGAs can run at these speeds but you can only have a tiny bit of simple logic. As soon as logic gets more complex routing and logic delays severely hamper the maximum clock frequency.
Surprised that this is an implementation of the full M68K instead of the Coldfire.  The Coldfire was designed for small size and performance.
Coldfire is not 100% compatible with 68k, so it may be a problem for a 68k system like Amiga.
the 68060 had many interesting features.  Fast instruction decoding and parallel Effective Address calculation.
Inside there is a RISC super scalar design, which makes things much more complex to be implemented, especially for the pipeline around the EA calculation for complex addressing modes (which go much more simpler in the 68000)
I have a lot of dubs, like yours, never used something so fast, never seen >400Mhz fpga.
Also, all my two toy-softcores (1) are using half the physically frequency provided to the fpga_clock, i mean in my case i usually use soft core_clock = fpga_clock / 2. I am using a pair of Xilinx fpga, a Spartan3 @ 50Mhz and Spartan6 @ 100Mhz, so in my case the max soft core clock is 25Mhz and 50 Mhz.
The "Apollo 68k-softcore" (2) seems to have fpga_clock equal to the softcore_clock, so 400 Mhz clock, it's unbelievable for me, unfortunately there are no sources, not released yet, so :-//
(1) the first one is MIPS3K compatible, the second is called "ponoku" and is a tiny-RISC ISA i have been developing, similar to MIPS2K but not compatible, they are both multi cycle, not pipelined, Harrvard approached without any cache because i want them designed the simpler they can go.
(2) i have discovered that it was previously called "Natami 68070", i think it is an other big source of confusion :palm:
Is this CPU core a hobby project, or something they are trying to sell?
good question, i can't understand  :-//
What i can say:
  • the TINA project is related to the mobo
  • this mobo uses fpgas in order to implement all of the features of an old Amiga 1200 (video, sound, process, and so on)
  • one of these fpga may use
    • the OpenCores TG68K soft core, which is  not superstar, and which is simple a 68000 compatible soft core
    • the Apollo Softcore, which is superscalar, super cpu, and you can't reach mars with it
About Apollo i have NO information, i only know this project was called "Natami"
About TINA it seems there is a small-company off the stage, but they have chosen to hide the company name.
here it is an other project which uses the TG68K, it is called "Vampire", it is an accelerator project for Amiga, and it seems someone has improved the old soft core trying to provide more features which makes it partially compatible with 68020
just an other ball of confusion from the Amiga Community :palm:
it seems sources are downloadable from here, you can give an eye, if you want
Offline BloodyCactus
    • KrÃ¥ketær
I believe this came about because people wanted something besides the TG68k softcore for other Amiga + AtariST projects. Right now the TG68k core has some issues, so of course people spin up other projects for 68k in fpga.
-- Aussie living in the USA --
yeah, it may be, what i can't believe is the superscalar version of the 68020, the Apollo-core (it was Natami core), or whatever they want to call it: it is too complex to be made for hobby purposes, very very complex to be validated, it consumes a lot of human resources.
Look at the date of the first Natami news: it was claimed in the far 2007, we are in 2014 (2015 in a few days) and … no Natami-core, dead project, dead code, dead hardware, everything is dead and nothing has been done/released etc, so they have changed the project name, and reloaded the game, again :-DD
The TG68K is a 68000 core, with a pipeline, not superscalar, and it has costed a lot of resources, it was claimed in 2007, and it was ready a few years ago, actually they want to improve it as 68020-compliant core, but it's thousand of million of light year away from a super scalar approach, so … i can't believe the Apollo/Natami/whatever core!
    • KrÃ¥ketær
natami. lol. lets take everyones design ideas, * 10000, include kitchen sink! at least its 'officially' dead now.
True, but when Coldfire was introduced, Motorola had a set of macros that were added to the assembler and it became assembly language compatible !
Much of what was left out were instruction and/or addressing modes that were very seldom used.
Very TRUE !  Unless multiple parts of the design are ASYNCHRONOUS timing distribution at higher speeds is CRITICAL !
If you look at the die photos of the DEC Alpha chip you can clearly see the clock line.  Why should something as insignificant as the clock show up on a die photo ?  Because the had to make it HUGE and drive it hard so that no part of the chip would have re-drive the signal an introduce timing variability !
If arts of the design are physically going to be on differnt FPGAs, they had better be asynchronous !
understood, but how tu run a legacy binary software, e.g. AmigaOS kernel and amiga Applications ?
i think such a macros and fixes are usable if you could rebuild from sources. Am i wrong ?
You are 100% correct !  I just ASSUMED someone had the sources !
Designing a general purpose CPU for multitasking because there are no "simple" benchmarks that are really relative to the application that is going to be run.  As I stated before, wider data paths, especially off chip data paths, are the simplest solution but have many technically issue for implementation.
My memory of the M68K instruction set is sketchy, but I seem to recall that there are instruction that modify memory contents directly.  These instruction are going to cause inherent delays (remember, memory access are always the slowest thing a CPU can do) as well as causing the write-back cache to be being dumped to memory.
Offline andersm
AmigaOS 4 and MorphOS managed decent binary compatibility for well-behaved software using dynamic recompilation on PPC hardware. I never had an Amiga, but IIRC even back then some applications needed hacks to eg. disable caches when using accelerator cars with '030 and higher CPUs.
Online nctnico
I notice a 68k core (TG68K) is mentioned in this thread. Is it any good?
TG68k scales bad if compared to a real 68SEC000 (which is ASIC core, used in Minimig v1, Amiga 500 fpga emulator)
  • 68SEC000 scales 1:10 -> 1 mips per 10MHz, stable up to @ 50Mhz -> max 5 mips
  • TG68K v2 goes for 2.75 mips @ 87.5MHz, it scales ~1:30
Apollo/N050 is a new superscalar design (yeah very confusion about this name), but closed sources, claimed to provide 800 mips @ 400 Mhz
Viper/Phenix is an other super-approach, derived from Natami, closed sources, and claims something similar, but no sources no party
personally i would like to see the next minimig made with a real 68040V (instead of the actual 68sec000), this 040 version is 3.3V so pretty compatible with the common fpga I/O without any voltage level shifter: it should be pretty superior in performance, and pretty validated than every softcore
i mean, i do not trust any Natami/Apollo/Viper/Phenix or whatever
this is an AGA Amiga on Fpga
Offline jaxbird
Dude, sorry, distinguished Sir, where can I buy this? the Amiga has always been my favorite 16bit machine and a classic from my youth.
Analog Discovery Projects: http://www.thestuffmade.com
Youtube random project videos: https://www.youtube.com/user/TheStuffMade
Offline jaxbird
Back in the days I got a genuine offer from one of my friends that he would let me sleep with his girlfriend if he could have my amiga 500 in exchange, I declined, while cute I did not believe the offer would be a fair exchange of such magnificent power for a simple sexual transaction. Anyway I managed to attract my own personal female just a few months after this exchange, no question the power of Amiga 500 helped me muster the required confidence for this awkward task.
I mean, cmon, they named it Amiga for a reason.
i don't know  :-//
try to contact the guy at www fpgaarcade com
asking for price and availability
btw, the question is: guys, do you believe a superscalar 68k softcore will ever be possible for hobby ?
do you believe it could have features like SMP, bus snooping, and very high performances ?
do you believe that, or do you really think that a 68040V + fpga (with AGA&C inside) is a more practical choice ?
Online Alex Eisenhut
  • Place text here.
...16 bit????
Offline miguelvp
The Atmel 68040V is very expensive. Even my Sega Genesis has a 68000 on it.
Maybe the Freescale variants MC683xx variants a better bet, but I'm not sure how compatible they are with the original.
Maybe this might help as a fast core:
https://code.google.com/p/fpgagen/source/browse/#svn%2Ftrunk%2Fsrc
It's a SEGA Megadrive/Genesis console in a FPGA developed for a Terasic/Altera DE1 board with VGA output.
Also let me privy you into the PACE project, but be warned, once you delve into this source code, there is no coming back.
https://svn.pacedev.net/repos/pace/sw/
Their forum is broken, I had to email the developer directly, but no one can post because the forum is still broken after a year or so.
http://pacedev.net/index.php?pageid=home
The developers old main website (hard to find btw)
http://members.iinet.net.au/~msmcdoug/
The developer now is working on something else:
http://ngpace.blogspot.com.au/
But I did warn you, there is so much in there that it's easy to get sidetracked at every turn.
The good thing is that he uses VHDL :)
Edit: And I forgot to point you to the PACE (Programmable Arcade Circuit Emulation) cpus with three 68K variants of cores two at least based or the same as the tg68
https://svn.pacedev.net/repos/pace/sw/src/component/cpu/
« Last Edit: December 26, 2014, 11:27:07 pm by miguelvp »
Offline jaxbird
...16 bit????
Sure the 68000 based Amiga (girlfriend) was a hardcore 16 bit based design with several helper GPU and sound chips making it far superior to the Atari ST.
how much is MC68040V ?
some MC683xx microcontrollers use the CPU32 core, others, such as the MC68302 family and the MC68306, use the 68EC000 core
but, there are no advantages using MC683xx, perhaps not about performances
it's confusing definition, the 68k is a 32bit cpu machine, the bus of the 68000 is 16bit, cpu registers are 32bit while graphical registers are 16bit, so … it depends on what you are talking about
Offline miguelvp
Only ones I can find on stock are north of $2K
http://www.findchips.com/search/ts68040
Price, they are available and way cheaper :)
Offline jaxbird
While the MC68K does have some 32 bit support, it is primarily marketing worthy with the CPU being mostly 16bit. As far as I remember it's got 32bit registers, but most instructions are 16 bit based.
TS68040MF33A
the idea of the MC68040V is that it is 3.3V core and 3.3V I/O (1), it seems to me TS68040MF33A is 5V
fpga needs 3.3V cpus and devices, if you put 5V devices you need voltage level translator (also bidirectional) 3.3V <-> 5V
yep, but the 68SEC000 is 3.3V, you can buy a new one for less than 10USD, and it goes (stable) up to 50Mhz
the problem is: it scales 1:10, so if you provide 50Mhz of clock, you get 5 * 10^9 instructions executed per seconds
that is not enough for my purposes  :D
(1) while the MC68060 is 3.3V core, and 5V I/O (i do not know if it can work 3.3V, too)
p.s. 68060 is not exactly 100% compatible with 68040, so .. Amiga needs special patches to be applied, these patches are called:
MC68060 SOFTWARE PACKAGE
The purpose of the M68060 software package (M68060SP) is to supply, for a target operating system, system exception handlers and user library software that provide:
  • Software emulation for integer instructions not implemented in MC68060 hardware via the new unimplemented integer instruction exception
  • System V ABI-compliant library subroutines to help avoid using unimplemented integer instructions
  • IEEE floating-point support for the on-chip floating-point unit (FPU) as well as software emulation of floating-point instructions, data types, and addressing modes not implemented in MC68060 hardware
  • System V ABI-compliant library subroutines to help avoid using unimplemented float- ing-point instructions
Offline Rasz
    • My random blog.
They were trapping unhandled exceptions, and resolved problems in the trap
You want hardcore? Here is some dudes Coldfire devboard to working atari port diary:
http://didierm.pagesperso-orange.fr/ct60/ctpci-e.htm
that coldfire hack is very very interesting, thank you  :-+
guys, anybody has seen a 68060 evaluation board around ? looking for something with just the CPU, ram, serial, and the expansion bus
in case, have you seen a full 3.3V system ? (both 68060 Vcore & IO powered at 3.3V)
this is a pretty discussion group about m68k board and CPUs
about 3.3V 68k core i am reading interesting things
  • MC68EC000AA10, M680x0 32-Bit, Speed: 10MHz, Voltage: 3.3V, 5V, 64-QFP
  • MC68EC000AA12,  M680x0 32-Bit, 12MHz, Voltage: 3.3V, 5V, 64-QFP
  • MC68EC000CAA10, M680x0 32-Bit, 10MHz, 3.3V, 5V, 64-QFP
  • MC68EC000EI12, M680x0 32-Bit, 12MHz, 3.3V, 5V, 68-LCC (J-Lead)
  • MC68HC000CRC10, M680x0 32-Bit, 10MHz, 3.3V, 5V, 68-BCPGA
  • MC68HC000CRC12, M680x0 32-Bit, 12MHz, 3.3V, 5V
  • MC68SEC000, M680x0 32-Bit, 20Mhz (overclock up to 50Mhz) 3.3V, 5V, 64-pin QFP 64-pin LQFP
it seems there is no 68EC020 at 3.3V, am i right ?
a brief summary list
Personally, I think "binary compatibility" is a "fool's quest".  Too many limitation to truly maximize performance.
I have been a big fan of Coldfire since the first one hit the market !  There is a very interesting "urban legend" about the Coldfire development.  Some is true because it did get published.
Once the lead designer had completed the 68060 design, he was not re-assigned to any specific project.  While working on the '060 he realized there were some interesting "short cuts" that could be made that would result in a smaller (cheaper) and faster replacement for the '020.  Because he was a "senior" designer, he actually design and built a prototype chip even though it was never targeted for production.
The rumor was HP was about to jump ship on their next generation laser printer because the '020 did not have enough "power" and anything above that was too expensive.  The engineer mentioned above got wind of this and said, "Hey, I got this chip I have been working on ...".  Some assembly language macros were thrown together to handle the the missing instructions and addressing modes and the rest was history.
Clock speed became "king" and for whatever reason Coldfire could not keep up.  At the same time Motorola had "hitched their wagon" to PowerPC (dumping their 88000 product line) so all efforts were placed there.  It loked like a good move until Apple went to Intel (word on the street was Apple got a HUGE discount on Intel chips for a number of years).  Motoorola did design and build a PowerPC chip for embedded (automotive) application, but that seems to have died out also.
ARM is the new "darling" of the CPU world especially the latest 64 bit version.  It is not "screaming fast" like Intel's desktop/server line, but its low cost and low power makes it attractive.  New implementations are only a step or 2 behind Intel on die shrinks.
Yeah, off course, but the problem about things like minimig is the AmigaOS & binary applications! With AROS&C (kernel and applications) sources you can do whatever you want, patching things, porting to Coldfire, PowerPC, X86, whatever (in the theory).
I think that is the reason why guys have started project like Natami/Apollo/Vampire/Phenix SuperScalar CPU made in fpga :-//
i mean, i think they wanted performances and full 100% compatibility with the real hardware (in case we are speaking about 68000 and 68020, something mounted on Amiga500 and Amiga1200)
my jobs is related to automotive, i am junior profiled but i can say our customers and all my four bosses are addicted for PowerPC quadric core, e.g. the e500 series used in Formula1 and MotoGB  :-//
Also Avionics is using PowerPC, made by IBM or AMCC, i mean PPC440, PPC460, or something like that (it may also be PPC405), they should be made around the PowerPC 603 core
Offline andersm
They probably did, but the main reason Apple switched to Intel is that neither IBM nor Motorola could make the laptop chips Apple needed.
Offline Rasz
    • My random blog.
ebay old nortel telephone switch boxes ~$50
http://www.ebay.com/sch/i.html?_nkw=NORTEL+NT5D10EA+CP+68060
Differences between 680x0 family and ColdFire
Although the ColdFire architecture is closely related to the 680x0, there are many simplifications to the instruction set. Nearly all of the differences are omissions from the 680x0 instruction set and addressing modes. This means that (with a few important exceptions detailed below), a 680x0 instruction which is implemented in ColdFire behaves in exactly the same way under the two architectures. In fact, almost all user-level (and much supervisor-level) ColdFire code can be run unchanged on a 68020 or later 680x0 processor (apart from new instructions introduced in the Version 4 ColdFire core). The converse, however, is not the case.
In outline, the main omissions fall into five categories:
Missing addressing modes
Missing instructions
Non-availability of word- and byte-forms of nearly all arithmetic and logical instructions
Many instructions act only on registers, not on memory
Restrictions on available addressing modes for particular instructions
Simplification of the supervisor-level programming model
Principles behind the differences
In order to understand the ColdFire instruction set in relation to that of the 680x0, it helps to have an appreciation of why the simplifications have been made. The philosophy behind ColdFire is influenced by the success of RISC processors in providing high performance - for a given degree of chip complexity - by eliminating seldom-used instructions and complex addressing modes, and by regularizing the instruction set to make it easier for the hardware to optimize despatch of the instruction stream.
However, standard RISC processors such as the PowerPC achieve high performance at the expense of low code density, in part because all instructions are the same width (generally 4 bytes) and also because only very simple addressing modes are available. In addition, RISC processors do not allow direct modification of memory locations; all memory reads and writes have to go via registers. This all means that programs compiled for RISC processors tend to be substantially larger than those compiled for CISC architectures such as the 680x0. This penalty does not greatly matter for desktop systems or servers with 32MB or more of RAM, but for embedded applications it can be a significant disadvantage, both in terms of system cost and power consumption.
The ColdFire architecture - which Freescale Semiconductor characterizes as "Variable-Length RISC" - aims to share many of the speed advantages of RISC, without losing too much of the code density advantages of the 680x0 family. Like most modern processor architectures, it is optimized for code written in C or C++, and instructions which are not frequently generated by compilers are amongst those removed from the instruction set. Some of the complex addressing modes - again not important for compilers - are eliminated, and the additional hardware complexities involved in supporting arithmetic operations on bytes and words also disappear. In order to regularize the instruction stream, all ColdFire instructions are either 2, 4 or 6 bytes wide; this is why certain combinations of source and destination operands are not available.
The ColdFire addressing modes are quite similar to those of the original 68000, i.e. without the extensions introduced in the 68020 and later processors, but with some differences in indexed addressing. Compared with a 68020 or later processor, the comparison is as follows:
Fully supported:
Data Register Direct
Address Register Direct
Address Register Indirect
Post-increment
Pre-decrement
Displacement (16-bit displacement)
PC Displacement (16-bit displacement)
Absolute Short
Absolute Long
Immediate
Partially supported:
Indexed
PC Indexed
The restrictions on these two modes are:
The displacement constant is 8-bit only;
"Zero-suppressed" registers are not supported;
The Index register can only be handled as a Long. Word-length index registers are not supported.
The scale factor must be 1, 2, or 4. Scale factors of 8 are not supported.
Not implemented at all:
Memory-indirect post-indexed
Memory-indirect pre-indexed
PC-indirect post-indexed
PC-indirect pre-indexed
Note that further restrictions may be imposed on the addressing modes supported by particular instructions, even if a particular addressing mode is itself available on ColdFire.
A number of instructions are not implemented at all under ColdFire. These include:
DBcc, EXG, RTR, RTD, CMPM,
ROL, ROR, ROXL, ROXR, MOVE16
ABCD, SBCD, NBCD
BFCHG, BFCLR, BFEXTS, BFEXTU
BFFFO, BFINS, BFSET, BFTST
CALLM, RTM, PACK, UNPK
CHK, CHK2, CMP2, CAS, CAS2, TAS (restored in V4 core),
BKPT, BGND, LPSTOP, TBLU, TBLS, TBLUN, TBLSN
TRAPV, TRAPcc, MOVEP, MOVES, RESET
ORI to CCR, EORI to CCR, ANDI to CCR
In addition, DIVS and DIVU (with some differences from the 680x0 equivalents) are available on some ColdFire processors but not others. MULU and MULS producing a 64-bit result are not implemented, but 16 x 16 producing 32-bit, and 32 x 32 producing (truncated) 32-bit, are available.
Long-word forms only
Most arithmetic and logical instructions can act on Long words only. This applies to:
ADD, ADDA, ADDI, ADDQ, ADDX, AND, ANDI, ASL, ASR
CMP, CMPI (word/byte forms re-introduced in version 4 core)
CMPA, EOR, EORI, LSL, LSR,
NEG, NEGX, NOT, OR, ORI,
SUB, SUBA, SUBI, SUBQ, SUBX
MOVEM.W has also been removed from the instruction set.
In fact, the only instructions which do act on the full set of byte, word and long operands are CLR, MOVE and TST (and CMP and CMPI in the version 4 core). EXT.W, EXTB.L and EXT.L survive, as do MULx.W and MULx.L
Instructions which act only on registers, not on memory
Some arithmetic instructions cannot act directly on memory - the destination must be a register. This applies to:
ADDI, ADDX, ANDI, CMPI, ASL, ASR, LSL, LSR,
NEG, NEGX, NOT, EORI, ORI, SUBI, SUBX, Scc
Note that ADDQ and SUBQ can act directly on memory.
Restrictions on addressing modes for particular instructions
Even where a particular memory addressing mode does exist in ColdFire, some instructions are subject to further restrictions. Often, this is because of the limit of six bytes as the maximum length of a single instruction. Specific restrictions include:
Some combinations of addressing modes for MOVE are disallowed. If the source addressing mode is Displacement or PC Displacement, the destination addressing mode cannot be Indexed or Absolute. If the source addressing mode is Indexed, PC-Indexed, Absolute or Immediate, the destination addressing mode cannot be Indexed, Displacement, or Absolute.
The addressing modes for MOVEM are restricted to only Displacement and Indexed - no Pre-decrement or Post-increment!
For BTST, BSET, BCLR and BCHG, if the source operand is a static bit number, the destination cannot be Indexed or Absolute memory.
Miscellaneous Omissions
There are a few miscellaneous omissions for specific instructions:
LINK.L is not supported
MOVE to CCR/SR: Source must be Immediate or Data Register
MOVE from CCR/SR: Destination must be data register
BSR and Bcc accept only an 8- or 16-bit displacement in version 2 and version 3 cores (32-bit displacements are reintroduced in version 4)
Instructions which behave differently from the 680x0 equivalent
In most cases, an instruction/addressing mode which does exist in ColdFire behaves exactly like its 680x0 equivalent, which makes it easy for experienced 680x0 programmers to understand ColdFire code. It also means that user-mode code written for ColdFire can generally run unchanged on a 680x0 processor, provided the new ColdFire-only instructions are not used.
However, there are a few subtle cases where the ColdFire instruction is not exactly the same as its 680x0 counterpart. The most important of these is that multiply instructions (MULU and MULS) do not set the overflow bit. This means that a 680x0 code sequence which checks for overflow on multiply may assemble and run under ColdFire, but give incorrect results.
ASL and ASR also differ in that they do not set the overflow bit - but this is less likely to cause problems for real programs!
Simplification of the supervisor programming model
Various members of the 68000 family have different register sets available at the supervisor level. The most important simplification in ColdFire's supervisor-level model is that there is only one stack pointer, shared for all code including interrupts, supervisor-level services, and user code. It follows from this that, on ColdFire, it is never safe to write below the stack, since any interrupt which occurs would overwrite the stored data. (Writing below the stack, though not recommended, is possible in some 680x0 systems in user mode, because interrupts cause a switch to the Interrupt or Supervisor Stack Pointer). A further issue is that ColdFire processors automatically align the stack to a four-byte boundary when an exception occurs, which can cause problems if code is reading or writing at a fixed offset from the stack pointer. In fact, it is strongly recommended (for performance reasons) that the ColdFire stack should be kept long-word aligned at all times.
New features in ColdFire Version 4 core
Version 4 of the ColdFire core architecture re-introduces some familiar 680x0 instructions, and also adds some new instructions. The main changes are:
Reintroduced:
32-bit displacement forms of BSR, Bcc and BRA
Byte and Word forms of CMP and CMPI
Slight relaxation of restrictions in addressing modes for MOVE
Restoration of the TAS instruction
New:
MOV3Q for moving immediate values in the range -1 to 7 to destination
MVS moves and sign-extends in one operation
MVZ moves and zero-extends in one operation
SATS Saturate register if overflow set
I have eaten a look at what’s still in production of 68k family and it seems there is not much else besides legendary 68000. Out of those, 68SEC000 version seems as best choice. It’s bvased on freshest manufactiuing process, and it comes in small package, low inductance
Also, SEC should be easier to OC while working at 3.3V Using 3.3V might be benefitial for:
– being able to find better other components at lower prices ( fpga )
– lower power drain
– lower noise on the bus
Other options fall off for one reason or another:
  • 68010, whole point of it was to fix a few bugs in 68000, that was needed to work good with external MMU. Since MMU brings extra waitstates and since 68010 is hopelessly obsolete for classic OS with virtual memory, this option makes no sense
  • 680(EC){020,030}, nice but not in production anymore
  • 68040, there are some 3.3V models stil in production, but it is outrageously expensive
  • 68060, not in production anymore
  • ColdFire, not really 68000 compatible
What surprised me most about Coldfire was the fact that it did not make a big impact in the automotive world.  GM had already been using the 68332 (IIRC, the CPU32 cores was not compatible with all 68k family member).  With its minimized instructions and addressing modes the Coldfire should have out performed the CPU32.  Additionally, Coldfires variable length instruction, which do require a bit more decoding than a fixed length RISC instruction set, should be a big benefit for application that execute out of Flash memory.
TPU and eTPU were criticized by some as too complex and in the early days lack of development/debugging tools were a major issue.  Motorola set themselves up to be the supplier of TPU firmware, BUT their solutions did not meet all customer requirements.
Designing an embedded system chip is quite different than designing a general purpose CPU chip.  Advanced designs that might have been dismissed, such as a 2 bank of general purpose/address registers (user, interrupt), are extremely beneficial in reducing context switch time.  Harvard architectures look like a good way of improving performance until you realize that much embedded code has literally thousands of constants.  The processor stalls while extra cycle are required to access the one bank of Flash memory.
i have bought a 68332EVS board (with a debug processor on it + original debugger software, x86, it needs DOS v6.22, it does not run on XP/NT/2K)
the TPU is amazing, i have coded a TPU-uart, TPU-pwm tasks very easily for micro robotic purposes  :D
Offline IanP
Re: Superscalar 68000, have you seen the Apollo core ? What do you think about ?
« Reply #57 on: September 24, 2015, 06:45:00 am »
The Apollo developers recently got their hands on the Vampire V2b card http://www.kipper2k.com/vampire/top.jpg. This is not the final V2 production card, that will have double the ram and double the data bus width. The much larger FPGA on the V2 card will allow a full Apollo implementation unlike the severely restricted, cut down Pheonix core on the V1 board which already performs pretty well. There's a lot still to do to have the full implementation of the Apollo core working on the V2 at it's full potential but work is progressing well http://www.apollo-core.com/bringup/index2.htm
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #58 on: September 24, 2015, 08:23:53 am »
That's the point or ARM's RISC concept; the Acorn people realized that the complexity of a CISC CPU that was intended to be programmed in assembly had to implement very complex/powerful instructions to simplify the assembly programmers work. The RISC concept, in contrast, implements very basic instructions and pushes the complexity into the compiler. This makes the hardware much simpler, which lowers the cost and complexity (allowing Acorn to build their own CPU for the BBC micro series computers). RISCs are simply not intended to be programmed in assembly.
Acorn RISC Machines then became ARM, which now licenses the RISC concept to lots of companies.
https://www.google.com/?gws_rd=ssl#q=Acorn+risc+machines+
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline John_ITIC
« Reply #59 on: September 24, 2015, 08:27:09 am »
NIOS II can obtain some 150 MIPS in a Cyclone V FPGA; the SoC version (hard CPU core) achieves some 4000 MIPS. That's a pretty good FPGA vs. ASIC speed illustration.
Offline ale500
« Reply #60 on: September 29, 2015, 10:03:45 am »
The guys at NatAMI did develop some boards based on an unknown (to me) MC68060 in QFP package. it is labeled MC68060FE133. It doesn't show up in any list of produced parts...:
http://www.natami.net/gfx/NAe60F/NAe60F_2.jpg
The discussion about a faster (and with new instructions) 68k core goes years back... sad that it is closed source :(
    • KrÃ¥ketær
« Reply #61 on: September 29, 2015, 01:20:21 pm »
it was never proved that the 68060fe133 were real. supposedly they were 133mhz 060's but.. these chips have no fpu or mmu. its a 68EC060 processor. the chip mask gives it away as a MC68LC060ZU66, as an overclocked 66mhz EC/LC mask chip.
afaik, after thomas found these in china and they were not found by anyone else again.
from memory, speculation was someone in china found some uncommon FE's and remarked them to 133mhz.  I think the final conclusion from like 2009? was it was a MC68EC060FE75 chip.
i stopped paying attention to natami back then lol
« Reply #62 on: September 29, 2015, 07:59:40 pm »
me too, it's a never ended project, and they have currently switched to Apollo-68K :popcorn:
Offline richardman
re:Apollo machines
My first job happens to be programming on the Apollo Workstation. This was before SUN (RIP) was huge, so there were dozens, if not hundreds of 68K based workstations popping up everywhere. The joke was that a workstation vendor would go to the Unix guys (I forgot which one now), and they would hand off a copy of the Unix-de-jour on a tape to them and they would release that.
Anyway, Apollo machines were made by Apollo Inc., not Mentor Graphics as a poster mentioned. They were 68K based, so they used 2 68K core executing the same code, and when one fell over due to memory paging, the other would check the content of the stack so the whole machine can recover. The 68020 solved that finally by putting more machine context onto the fault stack so all instructions can be restarted.
Apollo was bought by HP back in the days, around 1986 I believe.
Motorola/Freescale sold A LOT of Coldfires because that's the device family in the original Laserjets.
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
Smart.IO: phone App for embedded systems with no app or wireless coding
Offline grumpydoc
I wrote a bit of stuff for the Apollo post the HP acquisition as my university comp sci department had a few. Odd things in some ways and I spent rather more time swearing at them than I would like
The trick with two 68010's was also used by Sun - they didn't quite "execute the same code", one CPU was just behind the other so that when the first encountered the page fault the second could be stopped while the page fault was handled, then restarted - that CPU would never see the fault. Not sure how they synced register contents after the faulting instruction - possibly just execute that instruction, then copy from one CPU to the other? Anyone know?
Offline richardman
Yes of course they didn't execute the same code at the same time. Otherwise, they would just fall down together  >:D  I used to know the details, but too many things happened between 1980'sto 2015 :-)
What's pretty amusing to me though was that in the production CPU board, which is over 1 foot x 1foot, may be even more like 18" square, the back side is full of jumper wires to fix the hardware problems, and those were second generation production machines or something like that.
It also ran Aegis, Apollo's brand of not-quite-Unix because they wanted to write it in Pascal - I think. Again, too long ago now.
My first job was to rewrite the byte code interpreter from C to 68K asm. Took me a few days and sped up the runtime by 20-50x. This was for a semiconductor test company that had its own test language for the "next-gen" test machines. Those things ran at megahertz, blazingly fast at that time.
There were a lot of 68K workstation companies then, not unlike the PC clones later. At the last year of school, the luck few of us got to play with a Unix based "personal" workstation from Pixel. Think Steve Jobs' NextCube but 10 years earlier with lower resolution. One of my friends got a job at that place before she graduated but then the company went kaboo before she started!
Offline ale500
The original LaserJets are from early 80s, there where no ColdFires at that time. They probably had 68Ks. At least The Laserjet 2 Had a 68EC000 in PLCC package. Later machines, post Series 6 had them. Some had i960s...
never heard before, thank you for the news, is there any paper/AN/article/whatever (paper or digital copy) that tells it in details ?
Offline richardman
Correct, the original Laserjet had plain 68Ks, the later ones had Coldfires. Kept that Motorola unit alive for a long time! :-)
re: 68K page fault problem. You can get some links by searching for "68K page fault"  most are hand waving (one processor executes behind the other one...) descriptions, slightly lack of details. On thinking about it, it must be in the order of when the primary processor falls over, the secondary examines the state on the CPU and figures out what address it's having problem accessing (the issue is to implement virtual memory), and then fetches the memory block and restart the primary CPU. I know there are more in depth explanation as I read them before, so if I find them again, I will place a link here.
Offline ale500
I got the "SUN 68000 Board User's Manual" where the MMU of the 68000-Based SUNs is described, but it is only single processor. I think I got it from bitsavers. Maybe there is something apollo related there... I'll have a look now...
Another interesting document is this one: http://bitsavers.informatik.uni-stuttgart.de/pdf/sun/sun2/800-1185-01_2-120_CPU_Engr_Sep84.pdf
But nothing on those 2 CPUs systems so far... SUN No, HP No, Apollo also nothing... any other name ?
« Last Edit: October 06, 2015, 04:06:58 pm by ale500 »
thank you guys  :-+
Offline edavid
This is garbled... Apollo built a system with 2 68000s because the 68010 wasn't out yet.  As soon as it was available, they switched to a single 68010.
Sun never built a dual 68000 board, they waited until the 68010 was available to turn on demand paging.
« Last Edit: October 06, 2015, 04:48:28 pm by edavid »
Offline grumpydoc
I confess I never encountered such a beast so it is an old memory that is 2nd hand - I'm not surprised that it is inaccurate :) I must admit I thought Sun had used the dual 68000 thing, obviously not.
68010 when I meant to say 68000 was just a typo.
Offline richardman
Doing some reading, it's coming back to me. What is fairly certain is this: 2 CPU with one running one instruction behind. When one falls over, some actions happen:
  • one CPU examines the CPU state, and paged in the memory in question
  • one CPU resumes the program, now without the memory access issue
  • normal execution resumes
What is not clear is which CPU does which steps. Some people claim that the 2 CPUs swap roles. Obviously, in normal execution, the CPU executing "behind" cannot have its memory writes actually being executed.
It would be an interesting exercise to reverse engineer this. This hack though, must have been obvious to the hardware engineers at that time, that when one company did it, numerous other companies just went ahead and followed. This is before the sue-happy patent days, I guess.
Offline edavid
I don't think the "numerous" part is right - I don't think it was common at all.  For one thing, 68000s were very expensive, so no one wanted to pay for 2 of them, when Motorola was promising the 68010 very soon.  It made more sense to put the money into RAM.  Also, most of the early 68K systems shipped with a (crappy) Unisoft Unix port, which didn't even support demand paging.
As for the way it worked, what I remember (which may be wrong) was that the second CPU was run far enough behind that it could be interrupted and its pre-fault stack puke saved.  Then, when the main CPU was ready to resume the faulted process, it would reload that good stack puke and resume at the instruction that had faulted.
« Last Edit: October 06, 2015, 09:07:30 pm by edavid »
Offline richardman
The story was certainly passed around A LOT at that time (1984/85). The web forgets and now we only have truncated memory :-/ I suppose it has to be more than one, but who knows how many.
Unisoft was the company I was thinking about. They just handed out "build-of-the-day" to workstation vendors as official releases.
There was also a non-AT&T Unix vendor that claims to be independently developed until a couple Bell Labs guys did a dump on the kernel files at a trade show and found the Bell Labs copyright messages. Afterward, they quietly dropped some claims in their advertising.
Offline ale500
I only could dig that Stratus had a maybe similar 2-CPU design, if that was only due to its fault-tolerance or to fault-page... is not clear to me. But, no documents so far.
Offline richardman
Apollo Domain definitely had 2-CPU, and I am almost certain Pixel Workstation did also.
Offline grumpydoc
The more I think about this the more I think this one instruction behind business can't be correct.
I don't think the 2nd CPU could be more than 1 instruction behind otherwise you would have all sorts of problems keeping the CPUs executing the same code due to the effect of, or lack of writes to memory. Even then it might be hard, the lead CPU would probably have to have writes ignored - eg what happens if the lead CPU executes a test & set (an atomic R-M-W operation on the 68000). If the write is ignored, fine the 2nd CPU will see the unchanged value and take the same path but if not it will possibly take a different branch (since test-and-set is usually followed by a branch).
However if writes from the lead CPU are ignored think about what happens if code reads a value, modifies it, writes it back and then immediately reads it again. You probably wouldn't write code like that by hand but it could be generated by a compiler - especially one without much optimisation. The lead CPU write goes ignored so the read will get the old value.
You might fix the above by prioritising lag CPU writes  of main memory before lead CPU reads within the same cycle but what about instructions with wildly differing timings. Eg a register op followed by a DIV. The lead CPU will do the register op then start the DIV, at the same time the lag CPU will be on the register op but will move to the DIV while the lead CPU is still executing it. In that case the lead CPU would no longer be one instruction ahead, it would just be a few clock cycles ahead.
We haven't even thought about arbitrating the bus between the two CPUs
In short I can't see that the idea of executing the same code works.
What would work, however is that one CPU executes the code and the other just handles page faults. The CPU which is executing code is just delayed - perhaps by simply not asserting DTACK until the memory operation can complete.
Looking at a few of the online notes that is how the scheme is described.
Offline edavid
The lead CPU does all the memory accesses.  The 2nd CPU doesn't read live memory data, it gets the same data that the lead CPU saw (delayed by a FIFO).
I think that in some cases you have to decode what instruction caused the fault, and back out any pre-fault side effects.
If that was how they did it, they wouldn't have needed an expensive 68000 CPU for the service processor, they could have used a Z80 or whatever.
However, synchronous page faults are so slow, that it's not really worth building a system that way.
Offline grumpydoc
OK, but the lead CPU, by definition, can't complete the faulting instruction so you have to be able to have either CPU in the lead CPU role.
And putting a buffer/FIFO in there does not sound simple
Which doesn't sound do-able in the general case.
True but having two identical processors simplifies system design - both talk to memory the same way, you only need to write for one ISA etc.
I honestly remembered the story as two CPUs in lock-step but the more I think about it the more I think it is so much harder to do that than just having a system where one CPU does the paging while holding the other mid instruction. Occam's razor and all that.
Offline Bassman59
  • Yes, I do this for a living
At the bomb factory I worked for after college, we had a bunch of Apollo machines in an R&D lab. (Networked with token ring!) They ran Mentor Graphics Boardstation (I think!), and were used for analog board design and simulation. They were frightfully expensive (but, hey, bomb factory $$$). As I remember, yes, the hardware was made by Apollo, but the system, both software and hardware, was sold by Mentor.
It was a big deal when the machines were upgraded to 68040 motherboards. (Or maybe they were 030s? This was a long time ago.)
It was later than 1986, because I started at the bomb factory in 1988, and the machines were Apollo, not HP-Apollo.
Offline edavid
Sure it can... after the fault is resolved, the lead CPU is restarted at the faulting instruction.
Offline Rasz
    • My random blog.
you can restart as long as you are able to fire up interrupt on the following CPU before 'bad' instruction
Offline richardman
Cool. I worked for LTX, the test machine company (Left Teradyne at Xmas :-) ) only for 9 months. After a spinout on RT. 128 doing a 360 on a snow day was enough for me to say "THANK GOD I AM ALIVE. I AM QUITTING ASAP!" :-) and went to work for Whitesmiths, the company that produced the first commercial C compiler outside of AT&T.
So... back to the OP, this superscalar 68K core is... dead? Too bad. It has a lot going for it. I mean the 68K architecture.
OTOH, even the mighty Motorola, back in the days, could not bring out a 16/32 bits processor, in the forms of mCore. It looks and sounds great, but everyone was/is trampling to move to ARM...
Offline DJohn
Lock-step is the story I remember hearing, but it has to be urban legend.  It's too hard to make it work (if it's possible at all - what happens if there are two or more faults in the same instruction?), and the alternative is both simple and obvious.
The 68K will sit waiting for ever if you don't assert /DTACK.  When the MMU sees a request for a page that isn't in physical memory, all it has to do is interrupt the other processor, wait for the signal that the data is loaded (and the page tables updated), then tell the first processor to continue.  There's no need to restart any instructions.  The rest of the time, your second processor can be running useful code (anything that can't fault).
Offline grumpydoc
Not being funny but how does the FIFO know how deep to be?
I'm not overly familiar with 68k assembler (having done all my coding on such systems in C) but AFAICS a 68K instruction can do multiple reads - certainly up to three if both the source and destination operands live in memory. So if we could somehow lock-step instructions we would need to buffer a variable number of reads.
Offline edavid
I don't think it matters as long as it's deep enough.
I should probably stop trying to remember this stuff though, it's just been too long and it makes my head hurt :(
Offline edavid
This is a common misconception about demand paging systems... in practice, they are never built this way.  Demand paging only gives a benefit if you can overlap other processing with paging.
Offline Rasz
    • My random blog.
you are in the middle of instruction, afaik you cant hold cpu there (maybe can static variants?), load will fail and corrupt
Offline grumpydoc
It should be fine - by not asserting DTACK the CPU will insert wait states so it isn't halted or being held without a running clock. It's just waiting for the memory operation to compete..........
Offline ale500
Going back to the superscalar 68000 topic.... if someone (else) want to (also) undertake this, one possibility would be to make a code-morphing hybrid core/software package. That would also be quite an undertake... I'm tempted to do exactly that but for the simpler (but not by much) 6809, just as an exercise because I think there is not really much point wasting time in something this old and not that used, or is it ?
can you explain it ?
Offline ale500
You have a piece of software that converts a stream of 68k instructions into a stream of your super-fast-but-really-simple-processor instructions. Your simple super fast core can natively do in a few instructions what the 68 k do in one, but faster :).
There are a couple of possibilities regarding for instance flags calculation, they don't need to be calculated every time if they are not used. Such a system has a bit of latency but once going the throughput should be good...
Offline richardman
x86 does this since the late 90s. IMHO, not worth it for any new design - as there aren't a whole lot of existing 68K code anymore (except for old Amiga, Mac, ST etc.) so if you are going to do a fast 68K, then do a fast 68K. If you want to do a fast RISC, do a fast RISC.
Transmeta tried that too, RIP
Offline IanP
Just a little update on the progress of the Apollo core and Vampire 2. The Vampire 2 production board for the Amiga 600 began shipping 1 month ago (18th January 2016) to those that pre-ordered it. The boards are shipping with the Silver 1 version of the core described as "stable and fast" but not guaranteed 100% bug free. The Silver 2 version is expected to be released in the next few days. Vampire 2 users will be able to update to the Silver 2 core using an easy software procedure on the Amiga to field program the new core (no need to disassemble the computer). Silver 2 will fix some issues and likely boost performance a little. Next month is the target for production of the Vampire 2 for the Amiga 500 to begin, pending successful tests of the prototype boards. The specifications for the Amiga 500 version of the Vampire 2 are the same as the Amiga 600 version apart from the addition of a 44 pin IDE connector (like on the Amiga 600 and A1200 motherboards). Although targeted at the popular A500/A500+ this version of the Vampire 2 should also work in the original A1000, the A2000 and it's variants and possibly the CDTV. It is hoped that the Gold version of the Apollo core (including new features) will be ready in time to be installed prior to the first shipments of the Vampire 500 V2.
Modern Vintage Gamer reviewed and tested the Vampire 600 V2 with the Silver 1 Apollo core.
Lots more information available on the Apollo forums http://www.apollo-core.com/knowledge.php?b=0 where you'll find links to more videos and discussions about the Apollo core and the Vampire boards.
interesting  :D
Offline richardman
IMPRESSIVE!!!
Offline sleary78
« Reply #98 on: September 02, 2016, 01:13:43 pm »
So is the Apollo core available as verilog/VHDL or is it just an unlicensed rip off of the 68K series?
Offline edavid
« Reply #99 on: September 02, 2016, 02:56:17 pm »
What a weird question.
It's a softcore, but it doesn't seem to be available unless you buy the "Vampire" board.
Why would you call it a "rip off"?  Since when do you need a license to build a CPU emulator?  What kind of license are you even talking about?
« Reply #100 on: September 02, 2016, 03:23:44 pm »
Vampire is a fork, a branch, of the original project and buying a board doesn't come with sources
it's a commercial private project, be aware of that
Offline edavid
« Reply #101 on: September 02, 2016, 03:37:35 pm »
Is the original project source available?
Offline sleary78
« Reply #102 on: September 02, 2016, 04:46:43 pm »
Weird How? I've worked on many HDL CPU Cores... this is just another one but closed source.
A soft core? If its implemented in HDL then its not what i'd call a soft core. HDL can be fabbed onto ASICs. If its some sort of RISC cpu running a software emulation then fair enough.
ARM Ltd will threaten to sue you if you release ARM HDL cores/clones. Many of them have been taken off github and in the past google code. I expected Freescale/NXP would have a similar policy.
IMHO this is a 680x0 clone since it can be delivered in hardware form and can replace a real 68K. Hence its ripping off a commercially available chip. Its also probably breaking the licensing owned by whoever has the hardware IP from Amiga Inc if its shipping an AGA chipset clone too. So its a rippoff on two fronts.
Offline edavid
« Reply #103 on: September 02, 2016, 05:12:01 pm »
OK, but be aware that you have a different definition of soft core than everyone else.
That's because of their (stupid) patents.  It doesn't apply to 68K.
What 68K CPU is commercially available?
Anyway, why is releasing a compatible CPU a ripoff?  Are all the 8051 clones ripoffs?
Offline sleary78
« Reply #104 on: September 02, 2016, 06:05:29 pm »
I think we may be talking at cross purposes. The binary thats getting flashed into the Vampire II board is a softcore. However HDL sources (if they exist) arent. They're something you can create a physical ASIC from. This is what I am referring to. The topic title refers to the Apollo core not the Vampire core. There is a differents albeit its subtle.
Ok. thats probably true since the 68K is used in military applications and needs to be available from more than one source. I'd be surprised if there were no patents involved.
I know i got nervous about releasing my Archimedes core with an updated Amber ARM core in it. The patent had expired on ARM2 but I was still nervous.
Ripoff in this case implies clone. Not necessarily illegal or negative.
My issue with this project is that the HDL 68Ks out there so far are mostly GPL and i'm sceptical about a closed source core that may be building on GPLd work. If this was at least open source (but commercial) I'd give it less of a hard time.
« Reply #105 on: September 02, 2016, 06:17:55 pm »
last time I checked: - no -
and I am afraid it's still - no -
you can contact the ex-NATAMI team (Apollo-team)
and ask them for their sources
they might agree IF you have a valid purpose
e.g. because you are willing to develop a new-amiga platform
or to improve/test their core
or something similar
but keep in mind their code is NOT opensource
don't ask me why, I am not affiliated with them
I had a few interests in supporting 68K
so I started to check around, meeting their project
currently I am definitively not interested in 68k
since I am busy with my own toy-RISC project
Offline andersm
« Reply #106 on: September 02, 2016, 06:22:16 pm »
AFAIK the M68SEC000 is still manufactured, as the last of its kind.
« Reply #107 on: September 02, 2016, 06:25:08 pm »
what I know:
68SEC000 at 3.3V, very good for fpga, used by Texas Instruments
in order to build their TI89/TI92/Vojager CAS-calculators
(even if currently replaced by nSpire calculators, which are ARM-based)
68332 at 5V, used in military applications
and in some automotive applications, e.g. Ford Racing
mainly due to the legacy code and due to the TPU unit
Offline sleary78
« Reply #108 on: September 02, 2016, 08:38:31 pm »
My interest would be getting the core running on the MiST  platform which is probably not in the interest of the Apollo-Team. sigh.
Offline Rasz
    • My random blog.
« Reply #109 on: September 02, 2016, 09:44:43 pm »
no, last time I checked ~2? years ago authors were still deluding themselves into thinking they have something commercially viable on their hands and tried to peddle this 30 year old technology to IBM of all places (claiming it can scale >1GHz in asic and be competitive against powerpc).
Offline Tomorokoshi
« Reply #110 on: September 03, 2016, 02:01:02 am »
I turbocharged an Amiga 1000 by replacing the 68000 with a 68010 from an Apollo workstation.
For the most part it worked. Needed to run the "vbr" program to set the Vector Base Register. Some of the games and demos that did particularly egregious hardware banging had trouble running. Otherwise there was a nice speed improvement.
Offline edavid
« Reply #111 on: September 03, 2016, 02:09:00 am »
Why was it faster?  The 68010 is not any faster than than the 68000 except for "loop mode", which hardly makes a difference.
Offline Tomorokoshi
« Reply #112 on: September 03, 2016, 02:53:11 am »
If I recall, some of the instructions were optimized to use fewer clock cycles. The number I remember from the time is about a 10% improvement.
I found out about it either from newsgroups or magazines, besides, otherwise there wouldn't have been a need for the "VBR" program.
Offline sleary78
« Reply #113 on: September 03, 2016, 10:54:29 am »
I've just sent off for some boards to be made up of an 020 accelerator that fits in a 68K socket. Mostly i'm wanting to remove the need for PALs and move to a CPLD design. So its proof of concept work rather than production.
Offline legacyTopic starter
« Reply #114 on: September 24, 2016, 11:20:38 am »
Hi All,
i want to let everyone know in more detail why pricing has gone up, There was no possible way that i could get it done, I have spent hours locked up in my room trying to get these completed, as well, i have fallen way behind in other orders as people can testify and this is having an impact wit my sanity and patience. The amount of work and co-ordination required to get this all done is probably harder than what most people think. Add to this the constant flaming about people complaining that this should be handed over to a board house to get this done, and now we have people are complaining about the increased price.
Whenever you import parts bit by bit you can sometimes get them in under the radar, whenever you import expensive items the customs people rub their hands with glee and will gladly accept visa and your first born. Some people are cancelling their orders now and TBH i can understand. When we started this project and decided on the price we wanted to make this available to the masses and expected a small demand for the A600. I will never believe people who say they dont like the A600 as it appears there are at least 1000 active users of the A600. we were naive to think we could get this done at a lower price and people were excited to see this great product at a basement price, (Which it was). Once we made the decision to get the boards done professionally (at the request of a lot of people) we have now offended people at the other end of the spectrum. I have been receiving hate mail from people who are cancelling their orders and being accused of gouging, and multiple other reasons that we have used to increase the price.
I always said when it is no longer fun what i am doing then it is time to stop, So i will stop, Once the Vampire/Phoenix project is complete then it will be time to me to sell off existing bits and pieces and disappear into the woodwork. I am getting too old for this stress,
Thanks to all who supported me and to the rest, goodbye.
to the above poster, show me the $16 fpga we use from digikey ?
unfortunately the above drama happened here  :palm: :palm: :palm: :palm:
Offline CJay
« Reply #115 on: September 27, 2016, 12:56:24 pm »
That and it was easier to get 16MHz 68010 chips IIRC, you could then overclock it as well.
Offline ale500
« Reply #116 on: September 28, 2016, 07:03:43 am »
The code for the vampire board is available, the version I saw had a TG68K core inside.
« Reply #117 on: September 28, 2016, 11:56:45 am »
where?
the TG68k is not the Apollo-core
« Reply #118 on: September 28, 2016, 12:42:32 pm »
oh, I see a new commit of their web page  :o :o :o
« Reply #119 on: September 28, 2016, 12:43:55 pm »
Info: About recent events
Amiga FPGA accelerator
As you probably know participation in Apollo-team project was 90Eur, later on price went to 120Eur because design change. For that price you were getting Vampire 600 V2 accelerator card and opportunity to have fastest and most compatible Amiga accelerator ever produced, Apollo-core ported to Vampire card with unique features and with more than 100MIPS with latest published cores. From initial core release we went up for more than 20MIPS with adding more and more instructions, more compatible video output drivers and support for MicroSD. Everyone got opportunity to participate in this amazing project seeing it as a next best thing after minimig. Lot of people realized that we inside Apollo-team could bring something to the market, beyond wildest dreams of Amiga enthusiasts who waited for over 20 years for something like this to happen. As a person who worked on hardware design for last 6 years I was under constant pressure helping the team best I could in various areas with my modest knowledge. At the time when money was needed Amiga community recognized potential of this project and placed first pre-orders helping a lot financially. Without those people none of this would happen and that's the truth. They were helping me also in other things, getting parts, equipment. There was so many energy in the air send by them. That gave me the strength to work constantly more than 10 hours per day, every single day. For two years I didn't go to fishing properly or did something else like spending some time with the family.Don't know, just go somewhere with them. I didn't find time to do any other things, this project took it all. Project was frustrating, from the point that design needed change, five times, to the fact that in process of testings I had to buy parts who are now forgotten in those changes.
When you solder by hand about 3200 0402 capacitors and loads of other parts sacrificing in front of everything my health and then when you see that someone else is making money from your hard work then you start to wonder what are you doing wrong. From the start money wasn't my motivation. If that was the case I could sell this design number of times or I could increase the price more. Why solder by hand you may wonder. Because that was the only option to keep prices low and affordable to everyone, at least it was me who was talking constantly that no one should benefit from nostalgic feelings of retro computers enthusiasts. That's why I have opensourced first version of the Vampire 600 so anyone can continue work on it. If this was about the money then I wouldn't end up in the situation where I need to find money for future projects. I was forcing kipper2k to keep prices of the accelerators low with minimum profit or close to zero and each time one FPGA dies he is left with loses. And yes those things happen, I have loads of overheated or ESD damaged parts.
Lot of questions are in my mind lately, could we get even better results if we had money to pay someone for the drivers, demos, for the test cases, instead everyone inside team was working for free. With recent Intel purchases prices of the parts went even higher, yet we kept prices down because we had stock of the parts ordered before those Intel's takeovers. Same time people started to put their Vampire 600V2 cards on eBay selling it for anywhere between 300-800Eur. You may say that's not illegal and they can do whatever they want with their cards but please be in my position to work on this so hard and still don't have money for tooling fees needed for card edge connectors. Some people are adding themselves to our waiting list because pure profit they can make by selling the card five times more than they paid for. I was at the edge to block those cards from future core uploads but I didn't do it and I won't.
Since I have enough parts only to cover initial pre-orders placed on Amibay without need for more funds and because of recent eBay events I m forced to increase the price anywhere between 230-250Eur for various models. Without this decision we are dead in the water and we will hardly find money to finance Vampire 1200. I was idealist, thinking that I should play fair and give anyone opportunity to get this piece of hardware not respecting my time or energy and knowledge rest of the team put into this. I was an idiot thinking that everyone will keep their cards and follow our progress, they didn't even bother to try latest cores, instead they went for quick money. In the darkest corner of my mind I couldn't predict that someone will sell the card instantly when he gets it... Thank you eBay sellers for opening my eyes. World turns when money talks. Finally I learned that.
( link )
« Last Edit: September 28, 2016, 12:51:57 pm by legacy »
« Reply #120 on: September 28, 2016, 12:59:57 pm »
2015, Vampire V2, Gunnar von Boehn
(Apollo Team Member)
« Reply #121 on: September 28, 2016, 01:03:36 pm »
If you compare Coldfire V4 and Apollo then you see that:
1) Apollo can execute twice as many instructions per clock cycle.
2) Apollo can read/write twice as much data from Caches.
3) Apollo can process per instruction 64bit - so it can do twice as much work per instruction.
4) Apollo has automatic memory stream detection, and automatic hardware prefetching.
Each routine is different of course.
But for new code in general Apollo has the potential to be 4 times faster than Coldfire V4 at the same clock.
For old 68k Legacy code the situation is different.
As you know Coldfire does unfortunately _NOT_ support many 68K instruction and data sizes.
For example BYTE or WORD operations are not supported by Coldfire.
Coldfire will execute an exception when doing many 68K instructions. Executing such an exception takes many ~100 cycles.
We evaluated Coldfire V4 system during the NATAMI time and were disappointed with the legacy code speed.
I would assume for legacy 68k code, APOLLO is in the order of 100 times faster than a Coldfire core.
this may be interesting (written by Gunnar von Boehn)  :popcorn:
« Reply #122 on: September 28, 2016, 01:11:24 pm »
And Gunnar, if you allready have any plans for the future regarding commercial usage of your Apollo core. Do you plan to sell only your own hardware using Apollo core or do you have plans to sell the core also to other developers and how?
Sure, licensing the APOLLO Core is certainly possible.
« Reply #123 on: September 28, 2016, 02:51:13 pm »
September 28, 2016 at 14:40:50
message: hi
is it possible to see the HDL-code used in the Vampire accelerators ?
for personal use
let me know
Carlo
Dear Carlo,
Thanks for your email.
Apollo Core is closed source and we can't provide VHDL code.
Best Regards
Renaud
just asked directly to the team  :-//
Offline ale500
« Reply #124 on: September 29, 2016, 08:39:28 am »
Yes, they have a new core, but, here can you see that they used the TG68K:
http://www.majsta.com/modules.php?name=News&file=article&sid=77
Those are the sources, 0.1, that I saw.
Here you can read about some happy owners :) : http://www.amiga.org/forums/showthread.php?t=70424&page=3
« Reply #125 on: September 29, 2016, 10:08:02 am »
but TG68k is slower (by different orders of magnitude) than Apollo-core
and it's NOT used in Vampire as *product*
it's a personal choice that owners can do reloading their fpga's bitstream
it's like talking about TI-calculators, sold by TI with a proprietary TI-OS
but people can reload their own calculators with linux (with sucks great)
