Author Topic: The RISC-V HiFive Unleashed Linux dev board is available to order again  (Read 2206 times)
Offline brucehoultTopic starter
If anyone wanted one of these and missed out in the June 30 batch, pre-orders are now being taken for a production run for delivery November 30.
https://www.crowdsupply.com/sifive/hifive-unleashed
Offline aandrew
Re: The RISC-V HiFive Unleashed Linux dev board is available to order again
« Reply #1 on: August 08, 2018, 02:16:40 pm »
a $1000 dev board without a single high speed interface (not even PCIe x1) -- right.
I do believe that RISC-V has a promising future but until there is a reasonable dev platform for mere mortals I guess I won't be part of it. I did order one of their MCU boards (HiFive1) and a strip of bare chips for playing around with the architecture on the low end, but this is not a very good development system for the high end, IMO. This is a quad-core, network computer with a severe I/O bottleneck.
Online Monkeh
« Reply #2 on: August 08, 2018, 02:24:47 pm »
Ah, but you can buy the $2000 expansion board to get PCIe.
« Reply #3 on: August 09, 2018, 01:09:18 am »
No one expects to sell millions of these boards. For a start, the CPU is engineering samples sharing a mask set with whatever other sample chips TSMC is doing at the time. So you get 100 chips in each batch, with a several month turn-around. It's pretty easy to deduce from the figures on the CrowdSupply page that there were 100 chips/boards available in each of the March 30 and June 30 deliveries, less boards kept for internal SiFive use or delivered to major customers directly.
However, *customers* are going into full production with chips containing SiFive cores. There were three press releases about three customer projects yesterday. Multiple customers are reporting SiFive RISC-V cores are 1/3 the size and use 1/3 the power of competitors' cores, on processes ranging down to 7 nm.
Overview: https://www.bit-tech.net/news/tech/storage/sifives-risc-v-cores-launch-in-two-ssd-families/1/
FADU: enterprise SSD controller with multiple E51s (64 bit, no MMU) https://www.prnewswire.com/news-releases/fadu-launches-industry-leading-ssd-solutions-powered-by-sifive-risc-v-core-ip-300693176.html
Mobiveil: E51 and U54 complex (as in HiFive Unleashed board) combined with FPGA as a configurable SSD controller https://www.prnewswire.com/news-releases/mobiveil-inc-and-sifive-inc-partner-to-develop-risc-v-based-configurable-ssd-platform-for-data-center-and-enterprise-storage-applications-300693280.html
eSilicon: E2-series core (32 bit, 2-stage pipeline), in SerDes applications. This one is in 7 nm FinFET https://www.prnewswire.com/news-releases/esilicon-licenses-industry-leading-sifive-e2-core-ip-for-next-generation-serdes-ip-300692833.html
A FADU M.2 SSD incorporating SiFive 64 bit RISC-V cores:
« Last Edit: August 09, 2018, 01:27:36 am by brucehoult »
« Reply #4 on: August 09, 2018, 01:23:05 am »
Correct. Or you can use a Xilinx VC707 FPGA board ($3500) for the same purpose. The $2000 custom MicroSemi HiFive Unleashed Expansion Board gives a little bit of savings, as well as additional interfaces.
You can build the necessary bitstreams for the FPGAs on each board using Makefile.vc707-iofpga or Makefile.veraiofpga at https://github.com/sifive/freedom
The following users thanked this post: austfox
