Author Topic: Recommended smd replacements for DIP40 packaged 80C31 and 80C32 mcu's.  (Read 3752 times)
Offline AndersJTopic starter
80C31 and 80C32 DIP40 mcu's are more and more difficult to purchase.
Not to mention EEPROM and RAM, often used in these legacy systems.
To avoid rewriting software I would like to replace theses mcu's with smd devices,
with internal flash and RAM, and legacy on board peripherals such as timers, UARTs, etc.
Device suggestions are extremely welcome.
"It should work"
R.N.Naidoo
Offline up8051
Atmel/Microchip: AT89S51, AT89S52, AT89C51, AT89C52 ...
Nuvoton: W78 series
I think most popular body is PLCC44.
Regards,
up8051
Offline danmcb
  • if it ain't bust, I didn't test it yet.
    • McBee Audio Labs
I have a few tubes of unused Atmel EEPROM based 40 pin DIP 8051's if you are interested. I will never use them. If you are interested PM me and I will give you more info.
Offline pelule
  • What is business? It’s other people’s money
If I remember correct, the 8051(8751 could be used as 8031 if the EA pin was connected in the correct way.
Similar was with 8051/8752 and 8032.
/PeLuLe
You will learn something new every single day
Offline ohdsp
Maxim do the DS80C320/DS80C323 parts in PDIP and PLCC and TQFP. They look expensive though.
Porting over to a newer platform/chip could help with long term headaches if it is ever an option.
Check out the Open Hardware DSP Platform:
http://www.ohdsp.org
http://github.com/ohdsp
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
If you don't mind a changed footprint, you can try the STC15 series. Start with the top-of-the-line IAP15W4K61S4 (modern 1T core, 30MHz, 2.7-5.5V operation, supported on-chip debug) and work your way down their product tree.
Offline ebclr
I have a Rail of 80C31 never used any interest ?
Offline technix
  • Country: cn
    • My Untitled Blog
DIP or PLCC?
Offline ebclr
DIP
Offline technix
  • Country: cn
    • My Untitled Blog
DIP
How many of them do you have? And how much are you willing to sell them at? Also, date code?
Offline ebclr
Re: Recommended smd replacements for DIP40 packaged 80C31 and 80C32 mcu's.
« Reply #10 on: April 18, 2017, 02:30:57 am »
Where are you ?
Offline technix
  • Country: cn
    • My Untitled Blog
