A power board I made for a friend's ride-on car.
Originally it was very slow, old 6V lead battery and weak motor.
He replaced the system with 2x powerful motor and 2x 12 Li-ion batteries...
Very good at first but... guess what? He forgot about the wire resistivity.
The wires and switches melted after 5 minutes
It's no joke, the current exceeds 30 Amps uphill!
So I rewired the car so the wiring and switches now are only for low power signals.
The power goes straight from the battery to the motors through the power board.
The initial prototype is crazy powerful, as now the voltage drop is minimal.
Why the py32? Mainly to read the signals, but the real deal is the soft pwm start/stop, the motors were really violent when switched on directly.
I'm thinking on using the fwd/rwd gear lever as a sequential box, so while the pedal is pressed each change unlocks 20% additional PWM.
That kid is going to have the best car on the city
