Author Topic: TEENY TINY MICRO MINI 4 mm^2 ARM MCU  (Read 1237 times)
Offline richardman
« on: September 17, 2018, 08:11:16 pm »
How about a M4 MCU with FPU in under 4 square mm?
https://datasheets.maximintegrated.com/en/ds/MAX32660.pdf
The mind boggles at possibilities....
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
REXIS: RTOS for the IoT
Offline Mr. Scram
  • Display aficionado
Re: TEENY TINY MICRO MINI 4 mm^2 ARM MCU
« Reply #1 on: September 17, 2018, 08:18:13 pm »
Except that it's Maxim, so they won't sell it to you and leave you drooling at the gates. ;D
« Last Edit: September 17, 2018, 08:22:28 pm by Mr. Scram »
Offline newbrain
« Reply #2 on: September 17, 2018, 08:34:31 pm »
under 4 square mm?
I think you intend 16 square mm?  >:D
Edit: OOPS! there's also 1.6x1.6 package!
How did I miss that?  :-[
« Last Edit: September 17, 2018, 08:39:29 pm by newbrain »
Online NorthGuy
« Reply #3 on: September 17, 2018, 08:36:23 pm »
Mouser have them in stock, even a dev board.
For some reason, they didn't use the WCSP package (which is actually 1.6 x 1.6mm = 2.5 square mm) on their dev board :)
Offline richardman
« Reply #4 on: September 17, 2018, 08:56:15 pm »
It wouldn't make a difference in the devboard size  :P
Offline floobydust
« Reply #5 on: September 17, 2018, 09:21:25 pm »
$3 each and "Non-Stock; Due to temporary constrained supply, Digi-Key is unable to accept backorders at this time."
Eval Board: "No Stock 8/30/2018 - Delivery Date Past Due - Contact Digi-Key"
Offline richardman
« Reply #6 on: September 17, 2018, 10:12:18 pm »
They are in stock at mouser.com
Offline langwadt
« Reply #7 on: September 17, 2018, 11:16:18 pm »
so standard Maxim? ;)
Offline floobydust
« Reply #8 on: September 17, 2018, 11:30:21 pm »
No question it's a pretty powerful M4 in a tiny package, but stock of 25 seems like a teaser given the part was released Jan 2018.
If you're Maxim and trying to get a leg into the MCU market, this seems a bit low energy?
I have no idea how the peripherals are, for complexity and I then ran into:
"...Alas, you can't get a datasheet without an NDA"  http://www.ganssle.com/tem/tem358.html
Is this true, the tiny little M4 needs an NDA signed to get the datasheet?
Offline richardman
« Reply #9 on: September 17, 2018, 11:53:41 pm »
A simple search shows this:
https://pdfserv.maximintegrated.com/en/an/AN6659.pdf
What other info do you need?
Offline floobydust
« Reply #10 on: September 18, 2018, 08:21:07 pm »
Maxim site search for 'max32660' returns zero hits  :-//
Thanks for the link, I wanted to see how Maxim design and document the peripherals.
It looked clear, but a bit weird (brief) User Guide at 195 pages, whereas ARM MCU's tech manuals are typically 1,000+ pages.
This part dethrones Freescale's KL03 M0+ "world's smallest ARM microcontroller".
I wondered what you can do with only 14 I/O yet utilize 96KB SRAM, 256KB FLASH, 96MHz.
https://hackaday.io/project/160283-max32660-motion-co-processor
Offline richardman
« Reply #11 on: September 18, 2018, 08:29:34 pm »
The skimpiness of the ref man probably has to do with the fact that it only has basic I/O functions. Nothing fancy like USB, CRYPTO etc. I just ordered a devkit and will be writing some test programs. We will see how well the header files look and how well the Segger JLink works with it. It's pretty exciting with the large amount of flash AND especially SRAM!
Offline ogden
  • Country: lv
« Reply #12 on: September 19, 2018, 05:06:00 am »
Look here and you will see: https://www.datapine.com/blog/technology-buzzwords/
Offline rjp
« Reply #13 on: September 19, 2018, 06:49:22 am »
the Freescale   KL03 I recall it was intended for swallowable medical projects so the "96KB SRAM, 256KB FLASH" is intended to capture all the data before it ermm, passes out the other side.
Offline PCB.Wiz
« Reply #14 on: September 19, 2018, 09:05:00 pm »
Also very small, if you need it, is the new Nuvoton M2351 CIAAE  WLSCP49 (3.2x3.2 mm) - that packs 512kF, 96kR, and USB,CAN, 12b ADC 12b DAC .....
