How narrow a pulse can one generate on the RP2350B?
I'm curious if the RP2350B can be used to commutate several brushless motors. The STM32G4, some TI and Microchip parts can do single digit nanosecond wide pulses.
I've read the PIO document section but couldn't find a clock tree to work out the details. Thanks in advance.
Perhaps my comment will be DOA: but is it necessary for BLDC drive?
E.g. I'm just about to finish a PCB design with STM32H725 which has 275MHz timers. PWM at 25kHz => 275M/25k = 11000 steps per cycle. Divide by 2 for center alignment, so still 12.4 bits. Sure 16-bit resolution is better (you'd even have to slow down the timers on STM32G4 to get 25kHz), but in my mind I would also need to have 16-bit position sensors and 16-bit current sensing to match that resolution.
Other than the RP2350B looks like a fine candidate for 1 motor drive. I've ran some tests with SimpleFOC on the RP2040, and it could only do FOC ticks at 1-2kHz or so. That library uses floating point everywhere..
The RP2350B ARM M33 core has a FPU, so that should speed things up a lot. I measured the performance on a STM32H747 nucleo, and it was processing ticks in around 3.6-3.8 us. I would expect a RP2350B to be more or less on the same magnitude (my guess probably around 10-20 us per FOC tick). The more serious FOC controllers can typically do FOC loops at tens of kHz.
The second problem I had with the RP2350B for BLDC drive is its lack of ADC channels. The QFN-60 only has 4 , the QFN-80 has 8. It wouldn't make it unusable, but I would need 1 MCU per motor. Similarily, the timers only have 2 outputs per channel and no sync at all. Iirc the SimpleFOC library solved that issue by enabling all PWM slices at once.
The Raspberry Pi Pico's are fun chips with PIO etc. but its also clear they choose not to get into the way of ST, NXP etc. for these kinds of applications. The reason ST/NXP/etc. timer peripherals are convoluted as it is, is probably because customers want to build these kinds of applications with them. E.g. if your design is controlling a H-bridge directly, then ideally you'd also want complementary PWM outputs with hardware deadtime insertion. The STM32G4 can do that with HRTIM, many STM32's with their advanced-control timers, but these Pico's can't do it at all.
