First off, this is probably not a good place to get help/advice on parser generators.
should i open a thread
![](https://www.eevblog.com/forum/Smileys/default/confused0024.gif.pagespeed.ce.5xOqKkq0Co.gif)
Second point, why aren't you using flex and bison?
i am using flex, lex, bison, yacc, all the stuff you can get from linux (i can emerge whatever you suggest me, i am on a gentoo machine), it is my first time with these tools
Third, there's more to parsing than just copying someone else's grammar. You're also going to need a symbol table to keep track of things like 'my_t'.
yes, but i have read a few
lex & yacc tutorials, which are very easy about grammar, in fact the example is a "calculator", which i am able to write, and i wrote, by my hands.
You'll learn a lot more about parsers if you start writing your own simple grammar. Fixing reduce/reduce errors on a big grammar is no fun.
I have also written a Pascal-similar interpreter, you can find it in the link i have put in the first page of this thread. It is written easily, without any tools.
here it is the link of my thread, it is written in C++
In fact, if you're just starting out, try implementing a recursive descent parser because it's easier. You can use lex/flex for the tokenizer, but recursive descent can be done just with carefully written C functions--no need to generate code.
just asking for a tips&tricks, i repeat, it is my first time with yacc and C, also i need a C grammar implemented in order to realize a sort of sub-MISRA code validator. Too much work about designing it by hands, i mean, for me.
