Author Topic: TFT LCD pinout help  (Read 7586 times)
Offline odellTopic starter
TFT LCD pinout help
« on: October 26, 2013, 04:37:30 am »
I need some help with a TFT LCD driver board pinout. The LCD is a 7" inch TFT LCD module 800x480 SSD1963 w/touchpad PWM (link for the LCD would be below). The problem I'm having is I'm finding very little data for the driver board. I found a pinout to diagram for it. but that's basically what I found for it. if somebody can help me out with the name of the board or tell me what the abbreviations mean for the pins
  here is the link for the LCD http://www.ebay.com/itm/7-inch-TFT-LCD-module-800x480-SSD1963-w-touchpad-PWM-arduino-AVR-STM32-ARM-/121017488870?pt=LH_DefaultDomain_0&hash=item
Offline Harvs
Re: TFT LCD pinout help
« Reply #1 on: October 26, 2013, 05:02:00 am »
Did you notice that on that ebay page there's a download link for a ZIP file with everything in it?
« Reply #2 on: October 26, 2013, 05:36:41 am »
already looked at the download zip. nothings in there that I need. what I need is the 40 pin pin out diagram out of the LCD driver board and what the abbreviations mean on the pin out.
Offline Harvs
« Reply #3 on: October 26, 2013, 08:32:07 am »
Have another look.  There's a schematic with all pins labelled and all IC's labelled.
The datasheets for all those ICs are available by doing some googling.
I've used an almost identical LCD before, but I don't think there's anything I could tell you that's not on that schematic.
Offline David_AVD
« Reply #4 on: October 26, 2013, 08:55:49 am »
The pin names are pretty much the same for all those type of LCDs.  There's usually descriptions in the example code.  Download the SSD1963 data sheet as well.
