Author Topic: HV5812  (Read 821 times)
Offline franksterb92Topic starter
HV5812
« on: December 30, 2023, 08:13:00 am »
I'm kind of confused to how to drive this chip the function table  in the datasheet confuses me could someone explain how this works
Offline ttt
Re: HV5812
« Reply #1 on: December 30, 2023, 08:58:22 am »
That table is hilarious. Search on github.com for some sample code like this which looks pretty straight-forward:
https://github.com/Wiles/HV5812/blob/master/HV5812.ino
Re: HV5812
« Reply #2 on: December 30, 2023, 11:32:59 am »
So far from what ive gathered the 20 bits each bit Is clocked in by a low to high transition of the clock pin and a low to high transition of the strobe pin sends the data to the output pins so say if I want the output pins 1 and 4 high and the rest low I'd make data 1 then clock 1  data 0 clock 1 data 0 clock 1 data 1 clock 1 and data 0 for the rest of the bits then make strobe 1 to set the outputs
