I am working on what would today be fashionably called an "IOT" product.
After probably a man-year, plus loads of libs like ST ETH, LWIP, USB, etc (most of which were buggy as hell) the code size is 170k. Not bad for a 1MB FLASH CPU. The 128k RAM has 60k spare.
Now we add MbedTLS, so one can do HTTPS. Code goes up by another 150k and the 60k spare RAM is now 10k. The "Mbed" is a bit of a joke really
And what does it achieve? Very little, it seems. IOT boxes can't be on open ports, because these are discovered by sniffers almost immediately, due to back doors and vulnerabilities which cannot be fixed (a 100BN $ company like M$ is still patching back doors in Windoze after 30 years, so an embedded coder has absolutely zero chance, and then new ones will be discovered after the product is sold and installed somewhere) so their "internet access" can only be as a client, calling up some server, and hidden behind a NAT router.
But if you are calling up a server which you control, you don't need the whole TLS crap, with PK, session key negotiation, x509 authentication. You can just use a shared key, with AES256 or whatever. You have the key dist issue but with PK you still need 100% secure "access control" on each box because the private key has to be secure. You don't need auth because a fake server won't be able to read the data anyway.
And if the IOT box is to call up some "public service" server, the certificate for that will expire regularly, so you need the whole root certificate store, currently about 200k, and a means of periodically updating that, too
In the context of embedded systems, it mostly can't be done practically, and even if it can be done, it will sooner or later break or be forgotten (even the biggest firms have had their website certificates expire because the person whose job that was has left, etc).
It seems to me that a whole industry has grown up around this "security, privacy, etc" stuff and most of it is wasted.
The other thing is that "IOT" is going to end up with a really dirty reputation, as companies go bust, or just stop maintaining the servers. So the remotely controlled irrigation system, where you have a nice app connecting to that server, or even just a website served by that server, goes dead one day and there is no way to fix it. You have to rip the whole lot out.
