Author Topic: the last challenge is: how to detect if a stepper-motor is rotating  (Read 11730 times)
Offline donotdespisethesnake
  • Embedded stuff
Re: the last challenge is: how to detect if a stepper-motor is rotating
« Reply #50 on: September 16, 2018, 05:22:53 pm »
we are wasting our time
I have already solved the problem with a HAL sensor, attached to flat-cable. You can avoid wasting your precious time.
Common stepper drivers such as A4988 etc use a PWM output to the motor, I'm interested to see how the Hall sensor copes with that (I assume you mean Hall sensor).
Bob
"All you said is just a bunch of opinions."
