Author Topic: TI F280041C PGA analog input  (Read 184 times)
Offline stoyanoff
  • Country: bg
« on: July 04, 2020, 05:54:08 am »
Greetings! There is no answer from TI, so I need a little bit of help here! How can I select and convert data from one of the PGA inputs of F280041C? There is only 1 example into the lib -> pga_ex1_dac_adc_ext_loopback. So I`m using similar code, but I can`t get where I can change the read PGA input from. Here are parts my code:
#define MY_ADC_BASE ADCB_BASE
/*PGA enable I suppos*/
void initPGA(void)
    // Set a gain of 3 to PGA2
    PGA_setGain(PGA2_BASE, PGA_GAIN_3);
    // No filter resistor for output
    PGA_setFilterResistor(PGA2_BASE, PGA_LOW_PASS_FILTER_DISABLED);
    // Enable PGA2
    PGA_enable(PGA2_BASE);
/*ADCSOC init*/
void initADCSOC(void)
    // Configure SOC0. The temperature sensor is internally connected to B14
    // and requires an acquisition time of at least 450 ns.
    ADC_setupSOC(MY_ADC_BASE, ADC_SOC_NUMBER0, ADC_TRIGGER_EPWM1_SOCA,
                 ADC_CH_ADCIN1, 45);
    ADC_setupSOC(MY_ADC_BASE, ADC_SOC_NUMBER1,
                 ADC_TRIGGER_EPWM1_SOCA, ADC_CH_ADCIN1, 45);
    // Set SOC0 to set the interrupt 1 flag. Enable the interrupt and make
    // sure its flag is cleared.
    ADC_setInterruptSource(MY_ADC_BASE, ADC_INT_NUMBER1, ADC_SOC_NUMBER1);
    ADC_enableInterrupt(MY_ADC_BASE, ADC_INT_NUMBER1);
    ADC_clearInterruptStatus(MY_ADC_BASE, ADC_INT_NUMBER1);
/*my main loop*/
EPWM_enableADCTrigger(EPWM1_BASE, EPWM_SOC_A);
        EPWM_setTimeBaseCounterMode(EPWM1_BASE, EPWM_COUNTER_MODE_UP);
        ADC_forceSOC(MY_ADC_BASE, ADC_SOC_NUMBER0);
        ADC_forceSOC(MY_ADC_BASE, ADC_SOC_NUMBER1);
       // Force ADC conversion
       for(;;)
           if(ADC_getInterruptStatus(MY_ADC_BASE, ADC_INT_NUMBER1))
                       // Acknowledge flag
                       dacResult = ADC_readResult(ADCBRESULT_BASE, ADC_SOC_NUMBER0);
                       pgaResult = ADC_readResult(ADCBRESULT_BASE, ADC_SOC_NUMBER1);
                       //pgaGain   = (float)pgaResult / (float)dacResult;
In this case I`m receiving floating value for pgaResult and it doesn`t seem to change acording the value of any PGA input!
Any ideas?
Thanks!
Offline AkiTaiyo
Re: TI F280041C PGA analog input
« Reply #1 on: July 06, 2020, 12:25:23 pm »
I'm by no means a TMS320 expert but having a quick scan through the datasheet it looks like you need to sample the B9 input to get the output from PGA2.
From your code it looks like both of your inputs are reading from ADC B1?
Offline stoyanoff
  • Country: bg
« Reply #2 on: July 08, 2020, 12:30:31 pm »
YEs!  I finally got it! It`s very strange. I thought the PGA_OUT are for outputting the measurend sygnal. It`s confusing, but now it makes sence!
Thanks!
