Author Topic: TI MSP-EXP430FR6989 with BOOSTERXL-SENSORS Example Code  (Read 340 times)
Offline ALackOfNumbers
« on: October 29, 2020, 03:04:07 pm »
Has anyone tried to communicate with the TI sensors booster using an MSP-EXP430FR6989 development board? The sensor board comes with example code, but only for MSP-EXP432P401R and MSPEXP430FR5994. I checked the booster compatibility page, and the sensor board and my development board are compatible. I'm just not sure how to go about setting up the I2C communication. Anyone have any example code for this problem or good resources for I2C sensor communication on TI chips? Preferably without using RTOS, I just want to directly read accelerometer values from the sensor board and pass them through the MCU to my PC via UART without overcomplicating it.
Any help/advice is appreciated, thanks!
Online Warhawk
    • Personal resume
Re: TI MSP-EXP430FR6989 with BOOSTERXL-SENSORS Example Code
« Reply #1 on: November 07, 2020, 11:03:13 am »
You likely get a reply faster from the E2E forum from TI.
Meanwhile, you can check on dev.ti.com in the resource explorer for code examples (MSP430 ware)
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2 on: November 22, 2020, 03:07:40 am »
e2e is a good resource indeed, but you can skip the middle man and take a look at the Peripheral Examples of your device at the dev portal:
https://dev.ti.com/tirex/explore/node?node=AHzGW02kpuebA5.2Fvw5XA__IOGqZri__LATEST
Online Warhawk
    • Personal resume
« Reply #3 on: November 22, 2020, 09:26:23 am »
Which is exactly what I wrote one line above  :-DD
Offline rsjsouza
  • Eternally curious
« Reply #4 on: November 22, 2020, 02:35:04 pm »
I confirmed what you said but provided a link to the examples, as there are many points of entry for demos, middleware, peripherals, etc. So, less confusing to someone that may not be as experienced as others in navigating the portal.
The following users thanked this post: Warhawk
