Hello guys
I'm trying to port a Nokia5110 display from AVR to Stm32, but I have a problem with printing characters stored on the flash, the rest is working fine!
The original library is using program space to read from the flash memory :
void N5110_PrintStr(uint8_t x, uint8_t y, char *str, bool set)
uint8_t f_width = pgm_read_byte(&CurrentFont[0]);
uint8_t length = strlen(str);
for(int i = 0; i < length; i++)
N5110_PrintChar(x + (i * f_width), y, *str++, set);
for the stm32, I just removed pgm_read_byte:
uint8_t f_width = (&CurrentFont[0]);
the fonts are stored like this:
const uint8_t SmallFont[] =
/* Width, Height, Offset, Number */
0x06, 0x08, 0x20, 0x5f,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // sp
0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, // !
0x00, 0x00, 0x07, 0x00, 0x07, 0x00, // "
0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14, // #
0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12, // $
0x00, 0x23, 0x13, 0x08, 0x64, 0x62, // %
0x00, 0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x00, 0x1c, 0x22, 0x41, 0x00, // (
0x00, 0x00, 0x41, 0x22, 0x1c, 0x00, // )
0x00, 0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x00, 0x00, 0xA0, 0x60, 0x00, // ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00, // .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02, // /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00, // 1
0x00, 0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x00, 0x21, 0x41, 0x45, 0x4B, 0x31, // 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x00, 0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30, // 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03, // 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E, // 9
0x00, 0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00, // <
0x00, 0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08, // >
0x00, 0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x00, 0x32, 0x49, 0x59, 0x51, 0x3E, // @
0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C, // A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C, // D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A, // G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x00, 0x20, 0x40, 0x41, 0x3F, 0x01, // J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F, // N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E, // Q
0x00, 0x7F, 0x09, 0x19, 0x29, 0x46, // R
0x00, 0x46, 0x49, 0x49, 0x49, 0x31, // S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F, // W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63, // X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x00, 0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00, // [
0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, // Backslash (Checker pattern)
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00, // ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x00, 0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x00, 0x03, 0x05, 0x00, 0x00, // `
0x00, 0x20, 0x54, 0x54, 0x54, 0x78, // a
0x00, 0x7F, 0x48, 0x44, 0x44, 0x38, // b
0x00, 0x38, 0x44, 0x44, 0x44, 0x20, // c
0x00, 0x38, 0x44, 0x44, 0x48, 0x7F, // d
0x00, 0x38, 0x54, 0x54, 0x54, 0x18, // e
0x00, 0x08, 0x7E, 0x09, 0x01, 0x02, // f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g
0x00, 0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00, // j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78, // m
0x00, 0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38, // o
0x00, 0xFC, 0x24, 0x24, 0x24, 0x18, // p
0x00, 0x18, 0x24, 0x24, 0x18, 0xFC, // q
0x00, 0x7C, 0x08, 0x04, 0x04, 0x08, // r
0x00, 0x48, 0x54, 0x54, 0x54, 0x20, // s
0x00, 0x04, 0x3F, 0x44, 0x40, 0x20, // t
0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x00, 0x44, 0x28, 0x10, 0x28, 0x44, // x
0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y
0x00, 0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x00, 0x10, 0x7C, 0x82, 0x00, // {
0x00, 0x00, 0x00, 0xFF, 0x00, 0x00, // |
0x00, 0x00, 0x82, 0x7C, 0x10, 0x00, // }
0x00, 0x00, 0x06, 0x09, 0x09, 0x06 // ~ (Degrees)
Can someone tell me what I'm doing wrong! TIA
