I want to run some ESP8266 chips from single Cell LiIon batteries. Fully charged they have a Voltage of 4.2 / 4.1 Volt. The protected Typ will run down to 2.5 Volt. So my Input Voltage is 2.5 to 4.2V.
The ESP8266 has an input voltage of 2.5 to 3.6 Volt.
I have tried two Options:
a) connect battery direct to esp8266. Advantage: Working down to 2.5V cell voltage. Disadvantage: stressing esp8266 with 4.1 Volt. it is currently working, but its not a nice solution.
b) using a LM1117 voltage regulator. Works fine with an input of 4 Volt and down to input voltage of 3.5 V, still producing an output voltage of 2.5V. Advantage: Keeping the ESP8266 in spec. Disadvantage: stops working at a cell voltage of 3.5V
Before i try different switch mode power supply options, I would like to have some input on other real world solutions. All the tutorials have some sort of 5V usb power source.
i would like to optimize for battery life. The ESP8266 wakes up, reads a sensor, sends the data over WIFI and enters deep sleep for 5 minutes.
