Author Topic: TMS320 clones: has anyone tried them  (Read 1473 times)
Offline uer166Topic starter
« on: December 01, 2022, 03:44:19 am »
Per title, has anyone tried to do anything with TMS320 clones such as :
https://datasheet.lcsc.com/lcsc/2207061215_Haawking-HXS320F28034PNT_C2859021.pdf
https://datasheet.lcsc.com/lcsc/2207061215_Haawking-HXS320F28034PAGT_C3293111.pdf
They seem to be neat parts that can do lots of good stuff on the cheap, and wonder if it's similar to the Gigadevice/ST situation? Or something else (die copy instead of a re-implementation?). What do the tools look like? Is it binary compatible with TI?
Offline daisizhou
  • Country: cn
Re: TMS320 clones: has anyone tried them
« Reply #1 on: December 01, 2022, 05:09:21 am »
Do you mean the chip like in the attachment?
daisizhou#sina.com #=@
Offline thm_w
  • Non-expert
« Reply #2 on: December 02, 2022, 01:14:14 am »
Thats an actual TI part, or is trying to be, the parts OP is talking about are something else: https://lcsc.com/product-detail/Digital-Signal-Processors-Controllers-DSPs-DSCs_Haawking-HXS320F28034PNT_C2859021.html
It says RISCV so it might be equivalent to how the GD32VF103 is to the GD32F103 and STM32F103. In that its quite a change, and likely won't be binary compatible.
https://bbs.elecfans.com/jishu_2278016_1_1.html
Offline bidrohini
  • Country: bd
« Reply #3 on: December 11, 2022, 09:21:13 pm »
Nay. Even the Chinese datasheets are inconvenient enough for me.
Offline nomead
« Reply #4 on: December 12, 2022, 06:32:29 pm »
They seem to churn even more of C2000 look a likes with Risc-V core.
http://haawking.com/28027
http://haawking.com/28335
Online mkissin
« Reply #5 on: December 13, 2022, 07:52:36 pm »
These are interesting.
I'm not sure what the use case for them would be, since they use different core architectures and the C2000 has a very odd core (16-bit is the smallest addressable unit, etc...) which would mean code is extremely unlikely to work without a lot of checking and work.
Offline thm_w
  • Non-expert
« Reply #6 on: December 13, 2022, 10:36:28 pm »
Footprint compatibility, featureset compatibility (ePWM, HRPWM, etc.). Even if they have to rewrite most of the code, its worth it for some people.
TMS320F2802PZA seems to go for ~$8. So if you produce enough product using them, it might be worth it to port.
Dave recently had a teardown with a microinverter using TMS320. I'm sure they make massive quantities of those, its a huge market.
