Dear Ptricks
Thanks a lot for your reply, i never used silabs devices, I'm more familiar with cypress ones
From the technologies point of view, i experienced in the past all the 3 solutions I listed (so the 2nd one, I think is the one you are referring to, copper trace/pads made directly on a PCB that is below a glass panel or a plastic panel).
Now I'm trying to experience some more devices and I'm in the middle of the doubt between Pic and ATX - my main worry is related to the solution number 3, capacitive foil solution.
If you check any application note of any supplier, they'll tell you that you have to guarantee as much as possible distance between tracks from the sensing pad but, on the polyester foil solution, you have all the signal track that goes from the sensing pad to the foil tail connector itself almost parallel and very close, so it's very important to be able to filter noise, sensing and mutual couplings
So, I'm looking for any feedback about this specific sensing device (silver paste touch foil - generally speaking, it's like the ITO used above tft but it's cheaper that ITO because it is not transparent) together with PIC or ATX devices
Any feedback is appreciated
Thanks to everybody
