Author Topic: AVR Programming Issues  (Read 865 times)
Offline joeyjoejoe
« on: November 28, 2018, 11:50:58 pm »
I have an AVR (Attiny85) in a very basic circuit, using a a W25Q32JV (https://www.winbond.com/resource-files/w25q32jv%20spi%20revc%2008302016.pdf) memory chip.
I'm having problems programming it. Doing a bit of thinking, I realized the flash memory is probably interfering with the SPI programming. So, I put a 4.7k resistor to pullup /CS, which should hopefully keep that chip quiet. However, still no luck.
The output looks like it is properly talking to SOMETHING on the SPI bus.
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
Error during upload using programmer
The uploader process failed
I can probably just unsolder the flash serial chip and program it, but that wouldn't help much when it comes time to flashing new versions of the software.
Any thoughts on something obvious I'm missing?
Offline rstofer
Offline joeyjoejoe
Re: AVR Programming Issues
« Reply #2 on: November 29, 2018, 01:36:51 am »
Thanks!
