Author Topic: tricks, build diy soldering stencil out soda can  (Read 2228 times)
Offline legacyTopic starter
« on: November 20, 2014, 12:31:34 am »
A CHEAP WAY TO MAKE CLEAN ELECTRONICS
see this article  :-+
Offline gnif
  • Views and opinions are my own
    • AMD
Re: tricks, build diy soldering stencil out soda can
« Reply #1 on: November 20, 2014, 12:42:52 am »
Link broken, and this was published a long time ago on hack a day here.
« Reply #2 on: November 20, 2014, 09:40:08 am »
from italy i can open http://www.popsci.com/article/diy/build-diy-soldering-stencil-out-soda-can  :-//
btw, what do you think about ?
Tac Eht Xilef
  • Guest
« Reply #3 on: November 20, 2014, 11:27:00 am »
FWIW Popsci licences their name & some of their content on a country-by-country basis, and uses geolocation to redirect to the local website. What you get depends on where you are - you might get the full story, you might get a badly-mangled cut-down version, or you might get nothing. In this case, in Aus I get nothing but the local Popsci front page, and a search for "DIY stencil" finds nothing.
Basically, linking to their content is useless in many parts of the world. It's been going on for many years, many people have tried to convince them it's a bad thing, but they don't care.
(The quick trick around this sort of crap is to use Google Translate as a proxy - choose a language with a non-Roman characterset (e.g. Arabic), paste the link, and hit translate.)
