Electronics => Microcontrollers => Topic started by: plastygrove on January 20, 2018, 12:09:51 am
Title: TrueStudio v9 released - 100% Free but only for STM32
Post by: plastygrove on January 20, 2018, 12:09:51 am
Since I'm working with STM32 at the moment, this is good news. Just installed it and am happy to say the nag screen is gone and the pro features like memory and fault analyser are now available. To be fair, since v8 didn't limit the code size and I wasn't really using the pro-features, the real benefit for me is the annoying nag screen going away.
I suppose I'll have to now use a different IDE if I ever choose to use Atmel, NXP or any other ARM microcontroller apart from STM32.
Imported a project from v8 workspace to v9 and it works fine.
More details in the links below.
Blog Announcement (http://info.atollic.com/version-9-released)
Revision History (http://gotland.atollic.com/resources/manuals/9.0.0/readme.txt)
Download link (https://atollic.com/resources/download/)
Upgrade guide (http://gotland.atollic.com/resources/manuals/9.0.0/AtollicTrueSTUDIO_UpgradeGuide.pdf)
Title: Re: TrueStudio v9 released - 100% Free but only for STM32
Post by: mubes on January 20, 2018, 01:17:23 pm
The real good stuff about this move is that you get full access to things like swo and etb....that allows you to do logging and post-mortem analysis of how your code came to be at this place. It's a huge step forward for cortex-m to have this stuff available for free and a real game changer for ST.
The probes needed to support most of these features are cheap too ... A simple STLink or JLink is enough for basic output and, as far as I know, the stuff even supports JTrace for full fat streaming trace! I'm currently pestering them to support orbuculum and orbtrace cos that would give you trace output on a $25 adaptor board.
Dave
Post by: plastygrove on January 20, 2018, 04:11:44 pm
I had to google for SWO (Single Wire Output) and ETB (Embedded Trace Buffer) :). That's so cool, I had no idea Cortex-M was capable of such complex debugging capabilities. Definitely something for me to learn more about!
Post by: evb149 on January 20, 2018, 07:52:17 pm
Thanks, that would be a nice / interesting development.
I think the best and most scalable solution for them and other IDE makers would be simply to have an open interface specification between their IDE's debugging and programming layers and a hardware debugger /  target log I/O streams / tracing implementation in terms of some defined API / library or whatever.  They can keep their IDE and whatever as closed as they like but they should simply define the requirements that any external implementation must satisfy in terms of whatever ... C library API, scripts, software communication network sockets, file descriptors, pipes, whatever to let the IDE communicate with the implementation of the logging / tracing / programming / debugging features you want to use.
Then it would be relatively easy to have any tool work with the IDE seamlessly.
I presume this would have nothing to do with either "device drivers" or "hardware" since many debuggers can be used over say TCP/IP ethernet connections so the IDE to debugger/logger/tracer/programmer unit communication should mostly just be some simple serial / network protocol in the simplest cases.
I suppose also there might also have to be open documentation of how the logging / tracing / debugging / programming unit is also to talk to the MCU itself but I hope that such physical and handshaking / protocol interface documentation is already open and available for the MCU to tool hardware level.  I think that is probably mostly true for SWD, SWO, JTAG/cJTAG, DAP, ETB/ETM or what not though I am not sure of all the fine points.
Dave
