I basicaly copied and pasted the code for the first LED but changing all the variables of the second LED with a "2" at the end and used pin 11.
No errors but doesn't blink. I'm thinking they have to be in one loop or two different loops?
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
The analogWrite() function uses PWM, so if
you want to change the pin you're using, be
sure to use another PWM capable pin. On most
Arduino, the PWM pins are identified with
a "~" sign, like ~3, ~5, ~6, ~9, ~10 and ~11.
This example code is in the public domain.
int led = 9; // the PWM pin the LED is attached to
int brightness = 1; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup() {
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
int led2 = 11; // the PWM pin the LED is attached to
int brightness2 = 1; // how bright the LED is
int fadeAmount2 = 5; // how many points to fade the LED by
void setup2() {
pinMode(led2, OUTPUT);
void loop2() {
delay(30);
