Inductor and Output filter cap...what do you consider quite large? Depends on the input/output current and voltage your trying to work with, and the ripple, PCB size requirements you have to meet.
I've successfully designed and built several 20KHz PWM 16Fxxx 8bit low cost PIC MCU (20MHz) as the complete SMPS controller, circuits using external dual comparator and an a dual op-amp and so can use150 to 330uH inductors to make very efficient >5-amp Li-Ion chargers with simple cirucitry, and with a low-RDSon MOSFET, got a very high efficiency, losses mostly due to Schottky diodes, inductor resistance heating, but overall, very quite good results in regulation and ripple and high output current and yet capable of operating over a wide range of DC input voltages just a few volts over >Vbattery to >36V Vin.
The catch Sw. inductor size is, always the biggest hog of PCB real estate, followed by in/ouput filter caps, but total area needed is always in proportion to output current requirements..yet I have gotten very low cost, good size/efficiency/performance with output currents <3 Amp.
If have used a PIC MCU and a cheap IC comparator to PWM control a TI/Natsemi ~500KHz switcher IC output voltage with very good efficiency, 5-amp output, small inductor size and good regulation with acceptable load change transient response but the cost of the fast LM switcher is not so attractive considering the large quan. of free larger toroidial inductors I have on hand from defective PC power supplies and discarded PC printers, so I opt often to work with 20KHz PWM if PCB size is not an issue.
If you bother to build a freq. multiplier, your best bet would be dicard this idea in favor of using a MCU to control something like a LM2678 fast SMPS IC, due to the large circuit complexity.
