Author Topic: Ulta low power DACs  (Read 1936 times)
Offline t22456Topic starter
Ulta low power DACs
« on: October 13, 2017, 01:24:23 am »
As usual I have been put to task finding an ultra low power precision DAC. Product power budget is set at 500mW total. There are a zillion DACS out there so just asking if someone here has dealt with finding such a part. It has to be 16 bits, SPI input, and I think separate power supply for the analog output would be best but not necessary. Thank you in advance!
Online NiHaoMike
    • Facebook Page
Re: Ulta low power DACs
« Reply #1 on: October 13, 2017, 05:45:41 am »
You didn't mention what sample rate (SPI suggests an upper limit of a few Msps at most) but 500mW is not typically "low power". Did you mean 500uW?
« Reply #2 on: October 13, 2017, 12:53:12 pm »
The 500mW is the total system power budget including 2 ADC's, FPGA, uP, and 5 DAC channels. So single digit mW's or lower is needed. I may have to utilize shutdown mode to realize that kind of average power.
Offline ale500
« Reply #3 on: October 18, 2017, 02:18:27 pm »
An FPGA too ? in 500 mW ? Which one, can I ask ?
Offline RES
« Reply #4 on: October 27, 2017, 07:47:47 pm »
DAC8830 (voltage DAC)
Very Low Power: 15 uW for 3 V Power
High Accuracy, INL: 1 LSB
http://www.ti.com/lit/ds/symlink/dac8830.pdf
« Last Edit: October 28, 2017, 11:30:59 am by RES »
